ā03-05-2024 02:26 AM
Hi Team,
Please advise on how to upgrade CUCM from version 11.5 (11.5.1.13900-52) to version 15.X.
Is there a direct upgrade path available? If not, what are the steps for the upgrade?
Thank you.
ā03-05-2024 03:35 AM
You can find the needed information for this if you read the recommended list of documents for any upgrade. That would be these.
I recommend following the CSR compatibility guide and checking for the recommended versions. Additionally, make sure to read the following resources.
These resources will provide comprehensive information to answer your question.
ā03-05-2024 09:08 AM
The documents that @Roger Kallberg mentioned are crucial to read before the upgrade. Relying solely on someone elseās advice for an upgrade isnāt enough. In your case, youāre planning a Refresh Upgrade. However, please note that Refresh Upgrades from Pre-12.5.x sources to Release 15 are not supported.
In your situation, I recommend migrating from version 11.5 to 15. You have two options:
ā05-25-2024 08:20 PM
Has anyone else ran into the import issue with UCM 15, it boots up and when selecting the import option it gets stuck here.
It works for CUCM 12 and 14 but on 15 no go?
ā07-10-2024 11:26 AM
Do you know if it better now with v15 SU1?
ā04-18-2024 08:59 AM
