CUCM Upgrade Problem
muratg7777
I am currently running 8.5.1.13900-5 which is 8.5(1)SU3 and trying to upgade to  UCSInstall_UCOS_8.6.2.20000-2.
I checked the Cisco Unified Communications Manager Software Compatibility Matrix
I can directly upgrade to 8.6.2.20000-2 but I am getting "The selected upgrade is disallowed from the current version" error after a couple of minutes.
Any suggestions??? I know there are issues with MD5 but I don't think it is an MD5 issue.
I burned iso file to dvd.
Rob Huffman
Hi Murat,
Did you install;
ciscocm.refresh_upgrade_v1.0.cop.sgn
as your first step?
The details are in this good reference;
https://supportforums.cisco.com/docs/DOC-16898
Cheers!
Rob
Please remember to tag your threads and help support "Teachers without Borders"
https://supportforums.cisco.com/community/netpro/idea-center/communityhelpingcommunity
7 Replies 7
Rob Huffman
Hi Murat,
Did you install;
as your first step?
Cheers!
Rob
Hi Rob;
Thanks for the solution. I just upgraded to 8.6.2 with ciscocm.refresh_upgrade_v1.1.cop.sgn.
Cheers
Murat
Did you need any licenses after the instal (some software version licenses)? Because I tried to upgrade form 8.0, succeded, but phones wouldn't register because in licence information it said that software version licenses are missing.
So not sure if i should clarify it with licencing before upgrading client's server.
Also not sure if it happens because I am upgrading server which is running on demo license
thanks
Goran
Hi Goran;
I did not have problem with licensing.
Hi Goran
Yes, this is your issue. You cannot upgrade servers with a demo license. As soon as you do this, the demo licenses are removed.
You can only use demo licenses on fresh installs.
HTH. Barry
Hi Barry;
What if,  if you upgrade from demo licence and upload the licence after the upgrade?
Just tested it.
I added licence after the upgrade.
The configuration did not lost.
but you have to restart the services because it comes as disabled.
