04-02-2012 06:27 AM - edited 03-16-2019 10:25 AM
Hi ,
I am doing a upgrade from CUCMv7 to CUCM8. I have restored the configuration version 7 through DRS, and was sucessfull.
So, I installed the upgrade file in the server to install the CUCMv8, and was installed. Now I have in the CUCMv7 in the active partition and CUCMv8 in the inactive partition, but when I select Switch Version, and I have this message:
"error: Switch version disallowed during Licensing Grace Period Failed to Switch Version and Restart the Appliance"
What should I do?
What is the meaning of this message?
04-02-2012 06:38 AM
Hi Matthew,
It looks like this bug;
Description
Details
More
Less
Status:
Fixed
Last Modified:
Mar 29,2012
More
Less
More
Less
Product:
Cisco Unified Communications Manager (CallManager)
Platform:
Dependent
Severity:
3 - moderate
Cheers!
Rob
05-22-2012 07:59 AM
Hi Rob,
I have the similar scenario, I installed CUCM 7.1.5.30000-1 UNRST on new hardware and restored the backup, after restore I inserted the rehost licenses.
Now when I try to start the upgrade "Upgrade Install" returns (Upgrades are Prohibited During Licensing Grace Period).
I need to do the same workaround?
Thanks.
Joao.
05-22-2012 08:53 AM
Also this happened to me and I had to open a case so a TAC guy connected to my CUCM using root access and deleted a file in the licensing folder and then it started working properly.
Bye
05-23-2012 10:36 AM
Hi Cecilia,
Thanks for information, I open the tac and solve the problem.
Bye.
09-23-2012 07:02 AM
Do you remember how TAC solved this problem? I got the same issue, and this was my process. I'm upgrading from 7.1.5.10000-12 on MCS to 8.6 on UCS.
1. DRS backup production 7.1.5.10000-12 on MCS
2. Install 7.1.5.10000-12 on a VM. Yes, I get that it's not supported, but it should still work. I've done numerous upgrade from 4.x to 7.x on a VM to 8.x, and it always worked.
3. DRS restore
4. Now trying to upgrade to 8.6 and getting this error "Upgrades are prohibited during Licensing Grace Period"
It's gotta to be some simple trick with license files that could fix this. I tried installing rehosted NODE/PHONE license to the license mac, that didn't help. I tried removing all licenses, that also didn't help.
Do you remember what was the trick?
09-24-2012 06:23 AM
Hi Roman,
I did have the same problem, for solve the problem was necessary removed all old license files in database informix the CUCM. I opened the case in TAC because is necessary root account to delete files in database.
Regards.
João Rosa
