debug isdn q931
rmv72
Beginner
Beginner
Hi!
After upgrade Cisco2811 to IOS 15.1(3)T we have problem with outgoing calls. We got from PSTN switch error message-
Jun 14 10:15:55.361: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0xBD5F
    Cause i = 0x829C - Invalid number format (incomplete number)
    Progress Ind i = 0x8288 - In-band info or appropriate now available
    Display i = 'WRONG NUMBER '
From debug i see after
RX <- ALERTING
my gateway send
TX -> INFORMATION
and after it we got
RX <- DISCONNECT
Jun 14 10:15:45.341: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x3D5F
    Bearer Capability i = 0x8090A3
        Standard = CCITT
        Transfer Capability = Speech
        Transfer Mode = Circuit
        Transfer Rate = 64 kbit/s
    Channel ID i = 0xA9838F
        Exclusive, Channel 15
    Progress Ind i = 0x8183 - Origination address is non-ISDN
    Calling Party Number i = 0x2181, 'XXXXXXX'
        Plan:ISDN, Type:National
    Called Party Number i = 0x81, 'XXXXXXX'
        Plan:ISDN, Type:Unknown
Jun 14 10:15:45.361: ISDN Se0/0/0:15 Q931: RX <- SETUP_ACK pd = 8  callref = 0xBD5F
Jun 14 10:15:45.365: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0xBD5F
Jun 14 10:15:48.861: ISDN Se0/0/0:15 Q931: RX <- ALERTING pd = 8  callref = 0xBD5F
Jun 14 10:15:55.345: ISDN Se0/0/0:15 Q931: TX -> INFORMATION pd = 8  callref = 0x3D5F
    Sending Complete
Is it correct?
P.S. Number format is correct
Best regards,
Mike
Daniele Giordano
Collaborator
Collaborator
What is the number type of called and calling?
In your setup you have
Is it right?
Do you have already try to change?
You must use "isdn map address" command under serial interface.
Regards.
Daniele Giordano
Collaborator
Collaborator
Is it right?
Regards.
Certainly i have changed number.
Seems i have
CSCtb34920
Symptoms: Calls may intermittently be dropped or disconnected.
The debug output for "debug isdn q931" will reveal that the gateway is  sending a Q.931 INFORMATION message similar to the following:
Aug 11 13:51:20.137 EST: ISDN Se0/2/1:23 Q931: TX -> INFORMATION pd = 8 callref =
0x80AE
The connected service provider switch may respond with a Q.931 STATUS message similar to the following:
Aug 11 13:51:20.197 EST: ISDN Se0/2/1:23 Q931: RX <- STATUS pd = 8 callref = 0x00AE
Cause i = 0x81E17B - Message type not implemented Call State i = 0x0A
The connected service provider switch may also respond with a Q.931 DISCONNECT message similar to the following:
Aug 11 13:51:20.297 EST: ISDN Se0/2/1:23 Q931: RX <- DISCONNECT pd = 8 callref =
0x00AE Cause i = 0x81E4 - Invalid information element contents
But it seems it's resolved in last versions... How to check it?
The bug you are talking about does not affect your IOS version. The disconnect cause in the bug also is not the same as yours..So I dont think you are hitting that bug.. More details below os the IOS affected.
First Found in: (2)
12.4(24)T,12.4(15)T8
More
Less
Status:
Fixed (Resolved)
Last Modified:
Jan 12,2012
Known Affected Versions: (246)
12.4(9)XG5,12.4(9)XG4,12.4(9)XG3,12.4(9)XG2
12.4(9)XG1,12.4(9)XG,12.4(9)T7,12.4(9)T6,12.4(9)T5
Fixed in: (14)
15.1(24.6.13)PIL12,15.1(1)XB,15.0(1)M
12.4(24.6.11)PIB12,12.4(24.6)PI11v,12.4(24.6)M0.1
12.4(24)YE,12.4(24)T2,12.4(24)MDA1,12.4(24)MD
12.4(24)GC2,12.4(22)T4,12.4(22)MDA4,12.4(15)T10
Please rate useful posts
"For the love of God is broader than the measure of man's mind And the heart of the Eternal is most wonderfully kind"
Please rate all useful posts
"This problem may occur when an IP phone user blind  transfers a call to another destination (another IP phone, IVR, IPCC  queue, etc). The transfer request triggers the Cisco Unified  Communications Manager (CUCM) server to send an H.225 INFORMATION  message with a Signal IE to the Cisco IOS H.323 gateway indicating to  start/stop playing ringback tone toward the PSTN. The Cisco IOS H.323  gateway should generate the ringback tone, but it should NOT send the  Q.931 INFORMATION message toward the connected service provider switch. "
How to stop it?
Recognize Your Peers
