Deleting Phone information from CUCM Database
bobby.jacob
Can i know is there any way to delete ip phones which are regsitered to CM7.0, after the phones are disconnected physically?
We have CUCM 7.0 and 100 Ip phones registered. Auto reg is configured.
Requirement is- when the phones are physically disconnected from the network for a certain period of time shoud be erase from the CUCM DB automatically.
So whenever they connect back the phone physically after 1 day, it should register with a new DN.
Tnx
Bobby
Chris Deren
No, there is no such feature built in, you would need to develop some kind of application which could check the registration status and delete the phone via AXL. But no easy built in way, sorry.
HTH,
Chris
Hi Chis, what are the AXL commands for this to write application which could check the registration status and delete the phone via AXL? I can check registration status via JTAPI, but still need to know the SQL script or AXL command to delete the phone from CUCM.  Thanks
