Difference B/W 6921 and 7942 IP Phones - In terms of Ease of Usage
Jagsuvce G
Can some body give few major benenfits of 7942 IP Phone when compared to 6921 IP Phone in terms of User accessiblity and features.
Pls suggest.
Jagadish G
11 Replies 11
Aman Soi
Hi Jagadish,
a. 7942 weight is about 1.6 kg while 6921 standard model has 1.03 kg with slimline model as 940 gm.
b.in 6921 ,  there are fixed keys for xfer, hold and conference while in 7942 there are soft keys.
c. in 6921 , two colours : charcoal and white are available while in 7942 , u get dark grey colour.
regds,
aman
Nadeem Ahmed
The major difference which i can think and which is obvious hardware in terms of look and screen as compare to both of them. As 7942 support wideband and 6921 does not. Second thing 7942 has Speakerphone, Mute and Headset Buttons however 6921 has only Speakerphone, There are many other feature as compare 7942 to 6921 are there.
Please refere datasheet for 7942 and 6921 for more details
7942
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/phones/ps379/ps8535/product_data_sheet0900aecd8069bb68.html
6921
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/phones/ps10326/ps10343/data_sheet_c78-541534.html
Br,
Nadeem Ahmed
Please rate all useful post.
Br, Nadeem Please rate all useful post.
The 6921 does have headset and mute buttons.
GTG
Please rate all helpful posts.
Gordon Ross
Level 9
Level 9
Comparing a 6921 & a 7942 is a bit like comparing chalk and cheese.
The screen on the 6921 is tiny. The screen on the 7942 is massive.
If your budget can handle it, go for the 7942. You won't regret it.
Oh, and the 6921/6941 may be going end of sale soon, too. The new 7821/7841 are the official replacement for the those handsets.
GTG
Gordon Ross
Level 9
Level 9
You may find this helpful.
http://www.phone.cam.ac.uk/handsets/compare.php
GTG
Rob Huffman
Hi Jagadish,
+5 to my friends here for sure. Just one added note;
End-of-Sale and End-of-Life Announcement for the Cisco Unified IP Phone 6911, 6921, 6941, 6945, and 6961
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/phones/ps10326/eos-eol-notice-c51-730096.html
Cheers!
Rob
"When it comes to luck you make your own  "
- Springsteen
Hi Rob,
thanks for rating.
[+5] to you for sharing info on EOS.
rgeds,
aman
Thanks Rob for Hi5 rating :-)
Br,
Nadeem Ahmed
Thanks Rob for making me to stop searching for difference b/w 6921 and 7942, as 6900 is going EOL.
Also i did lot of research... in 6921-C-K9 all features are available like headset, mute, speaker buttons and also soft keys. Only features like display screen and wideband audio is not available in 6900 series.. if am not wrong. Am attaching the snap shot of 6921-C-K9 for your reference.
Now i need to think of 7821 series IP Phones. I was referring the data sheet and in Signalling Protcols it says only SIP ?? Is SCCP not supported by 7800 series ??
Pls suggest on b/w 7821 and 7942 series IP Phones.
New phones nowadays are SIP.  CallManager should be able to support SIP.
Why fear SIP? There is now feature parity for endpoints running SIP & SCCP. (OK, Except for phone VPN support on the 79xx phones)
Cisco have stated that going forward, SIP will be the prefered endpoint protocol (but they will still be supporting SCCP for a long time) Some of the newer endpoints, in fact, only support SIP.
GTG
