07-27-2017 11:14 PM - edited 03-17-2019 10:54 AM
How to get Company name Display on Cisco IP phone
07-28-2017 02:10 AM
What are the details of the setup, do you have a CUCM or CME? What kind of IP phones are involved and what is the exact call flow? Where would you like the company name to be displayed, for outgoing calls to PSTN ?
Manish
- Do rate helpful posts -
07-28-2017 05:14 AM
Hi Manish/keanej
My Question was wrong here apologies,I want display Company name on background on the handset.
I got the Answer from Kenej,Let me try.
Thanks for your Support.
Rakesh
07-28-2017 02:22 AM
Its possible to change the background on the handset, you can put your company logo here (and it looks great!)
This depends on the handset you are using
For example for a 7945 handset...
You need to use image editing software (possible in MSPAINT)
You need two images -
320 x 212 pixels 16 bit Colours
080 x 053 pixels 16 bit Colours.
So you need to company logo image in these formats.
You then need a list.xml file that references these and then upload the 3 files to Call Manager.
That's the rough procedure...
This this link for the extensive details
http://www.voicecerts.com/2011/08/changing-cisco-ip-phone-background.html
Then
