Does Cisco make a conference room phone that can connect to an external room audio system?
wkarpinski
We are currently using a Cisco 8831 in some large conference rooms and would like to have a phone that can connect to an external vendor audio system to use the room microphones and speakers.
Any suggestions?
Jonathan Schulenberg
Look at the Room Kit Plus or Pro for this sort of thing. Video isn’t required; you can run them in headless mode for audio-only use cases.
https://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/webex-room-series/datasheet-c78-741052.html
Ratheesh Kumar
Hi there
I suggest you should check out the Cisco Project Workplace https://projectworkplace.cisco.com/#/en-us
Flip through a variety of room designs and choose the room type that best fits your telepresence and video conferencing needs. Project Workplace provides technical drawings that show you how to set up the different meeting spaces, You'll also find tutorials on other aspects of setting up meeting rooms.
Hope this Helps
Cheers
Rath!
***Please rate helpful posts***
Mike_Brezicky
You can always check with the external audio system to see if they have a SIP line capability, then you can register the system as a Third Party SIP endpoint, controllable from CUCM. I use this in many of my Crestron / Biamp controlled rooms. I am however looking to move them to a Room Kit Pro in the future for a better overall integration.
George Sotiropoulos
I have widely used Creston Audio Systems which has never dissapointed me.
Hope the above helps,
gsotirop
