Does the Cisco 2811 support two VIC2-4FXO card?
davidmejia
I am new, I have to design a network with 8 port FXO, so I was wondering if the Cisco 2811 could support two VIC2-4FXO card?
paolo bevilacqua
Yes. Remember that you need DSP (PVDM2).
Hi Paolo, Thanks for your help, for the DSPs do you recomend the PVDM2-32? do you think it would be enough?
A PVDM2-32 will support 32 G711 streams so that would be more than enough for your 4FXO card.  A cheaper solution might be a PVDM2-8.
