04-06-2011 01:24 AM - edited 03-16-2019 04:21 AM
Hi guys,
is anyone able to help/advise on the following?
I have a CUCM 7 and a CUCM 8, I need to setup an E1/T1 link between the 2 callmanagers
the CUCM 7 is connected to a Cisco 2821 which has an E1 PRI card and the Cisco CUCM 8 is connected to a Cisco 2811 with also an E1 PRI card.
the callmanagers is literally in the same room but because I work for a telephony company that tests our own devices with Cisco we need to set this link up between the two call managers. We have a SIP trunk setup but also need E1 between the two.
I understand that both routers need to be configured for MGCP.
if anyone could help or advise I'd be most greatful
04-06-2011 01:55 AM
You actually have to use H.323 or SIP because to my knowledge, MGCP does not supports ISDN network side.
Beside that, have you considered engaging a certified cisco partner or reputable consltuant to have this (and other) problems solved quickly ?
04-06-2011 05:33 AM
Hi Paolo,
First of all many thanks for taking the time to reply to my post.
Are you able to send me a link to some information that can confirm what you have just said about ISDN not being supported on MGCP?
The strange thing is that the CUCM 7 side of things under Gateways on the CUCM web interface says that the interface is registered.
I'll attach a screen shot of what I see and also the config from the Cisco 2821.
The answer to your other question - Yes we could get a Cisco engineer in to help us but we like to give it our best effort at resolving our problems 1st and then if all fails we contact Cisco.
