EM in CME 8.6
acharyr123
Level 3
Level 3
I have configured EM in CME 8.6..Attached configuration for your reference. I am using 7942 phones.
I press service button & select EM, it asks to put username & password. I put the credential: username: partha, password: cisco. The phone goes to reset state & doesn't come up properly until i do a manual reset. Once i press Logout, the phone gets stuck. Once i manually reset the phone, the phone doesn't give me the DN number at all that i configured in the logout profile. Attached the EM config.
CME version: 8.6
IOS: 15.1
Phone type: 7942
voice logout-profile 1
pin 1234
user 1 password cisco
number 002 type normal
voice user-profile 1
pin 12345
user partha password cisco
number 004 type normal
telephony-service
no auto-reg-ephone
authentication credential webadmin c1sc0@123
timeouts interdigit 2
url services http://10.111.220.33/voiceview/common/login.do
url authentication http://10.111.220.31/CCMCIP/authenticate.asp
ephone 1
logout-profile 1
Kindly suggest:
11 Replies 11
paolo bevilacqua
Please mention exact IOS and phone firmware version.
CME version is: 8.6
IOS: 151-4.M3
Phone Firmware: cmterm-7942_7962-sccp.9-2-3
Rgds,
Partha
Can you try phone FW 9.1.1SR1 ?
I tried the FW suggested by you..but the issue remains same…any suggestion plz !!
Rgds
Vipul Jindal
do you have any ip http port configured??
thanks,
vipul
Ip http port is not configured.
Rgds,
Partha
Have you configured your ephone-dns for the actual DNs on the logout/user profiles?  (003 and 004)
Chris
I have done the following:
pin 1234
user 1 password pcs1234
number 350 type normal
pin 1234
user partha password pcs1234
Ephone 6
Logout-profile 1
Type 7942
Mac
Rgds,
Partha
Try:
ephone-dn 1
number 350
ephone-dn 2
number xxx (put whatever you were going to have as your user profile dn here)
number xxx (number created above)
Chris
Thanks for your reply…I configured as you suggested, but the issue remains same. If I press Logout, the phone hangs..i need to press the exit button then only it works….same thing happens while logging in into EM…any suggestion!!
Rgds,
partha
I am having the same issue with CME 8.6 , IOS ver 15.1(4)M4 , and Phone firmware ver 9.1.1 . When I login or logout of EM it hangs until you press exit a coule times. The profile loads fine and it works after hitting exit a couple times and the same when you logout, it hangs until you press exit a couple times. Has anyone come up with the fix on this yet? thanks.
