Em Phones Callmanager
miket
Level 5
Level 5
         Has anyone seen this tyoe of behavior. When a user logd into a phone using EM, then you search on extension of the EM Profile you cannot find phone the only way is to use route plan report
I dont seem to remember this in version 6 or 7
11 Replies 11
Aman Soi
Hi Miket,
This is the normal behaviour.
You can get the details of Users who have logged in EM through Actively Logged in Device .[DEvice---Phone---Actively Logged in Device from Related Links ]
the other way u have already mentioned is from Route Plan Report.
regds,
aman
Amanso ,  I  tried both methods and it doesn't work  From the route plan report I can see it but from logged in device
I cannot
Hi Miket,
Are the agents logged in when you are trying to get  from Actively Logged Device?
U will get only when agents are logged in .
regds,
aman
YES they are logged in,, Can call them go to voicemail etc etc
Strange behaviour
Hi Miket,
You can only see User logged through Actively Logged in Device tab.
Another option is go to: Cisco Unified Reporting->Unified CM Extension Mobility (
Extension Mobility Logged in Detail): https:///cucreports
Please remember to rate useful posts clicking on the stars below.
Favor calificar todos las respuestas útiles.
___________________________________________
LinkedIn Profile: do.linkedin.com/in/leosalcie
__________________________________________________
Hi Miket,
Can u try other way as suggested by Mr. Leosalcie?
What is the CUCM version u are using and agents have logged in through which IP phones model?
regds,
aman
I have, when check the actively logged in it misses people  I am at 8.6.2a
the report shows 208 logged in  , profiles logged in 208, em profile 309 phones with em enabled 278
Hi Miket,
What u are saying is that under Unified Reporting , report is correct but Actively Logged in Device  shows nothing ?
Is that correct?
regds,
aman
Almost reports show what I said in Post howeve the Actively logged in shows some but not all phones logged in.,
Miket, it should display all pphone logged running extension mobility. Are you sure about that?
If Cisco Unified Reporting is working fine so just use it .
Positive. I verified the mac and the user is logged in and you canot find them . Route plan report is ok  Just Actively logged in doesn't show him
