10-08-2016 03:58 AM - edited 03-17-2019 08:18 AM
Hi all,
How can i enregistring 8851 IP Phone in CME??
Thanks in advance
MM
10-08-2016 04:30 AM
If your question is how can i register a 8851 phone with CNE then you can refer to the document below:
https://supportforums.cisco.com/document/69331/sip-phone-9951-configuration-cme-85
The document is for 9951/71 but the steps are exactly the same and only difference is the ephone type.
Aseem
(Please rate if useful)
10-08-2016 04:43 AM
thanks Aseem for your reply,
but type 8851 is not devined under " voice register pool"
thanks
10-08-2016 05:06 AM
Please share the output of:
Show version
Show telephony
Aseem
10-08-2016 10:44 AM
Please note 8851 is not supported natively till CME 11.x hence you will require to register it in Fast Track mode in case you are running a CME version less than 11.x there. Check below Compatibility Matrix for your version:
http://www.cisco.com/c/en/us/support/unified-communications/unified-communications-manager-express/products-device-support-tables-list.html
You can refer to below document for sample fast track configuration and use 8945, 9951 etc in reference pool type command
https://communities.cisco.com/thread/39200?start=15&tstart=0
Deepak
03-30-2017 12:38 AM
I registered phone 8851 in CME 10.5 using fast track.
Example:
voice register pool-type 8851
xml-config maxNumCalls 6
xml-config busyTrigger 6
num-lines 77
description Cisco IP Phone 8851
reference-pooltype 9951
voice register global
mode cme
source-address x.x.x.x port 5060
max-dn 20
max-pool 10
load 8851 sip88xx.11-5-1-18
authenticate register
authenticate realm all
timezone 43
voicemail 810
tftp-path flash:
create profile sync 0574892224431425
conference hardware
video
voice register dn 3
number 103
allow watch
pickup-group 100
mwi
voice register dn 5
number 111
call-forward b2bua busy 810
call-forward b2bua noan 810 timeout 3
mwi
voice register dn 16
number 153
allow watch
pickup-group 100
label Main Incoming
mwi
voice register pool 3
id mac 0038.DFB4.xxxx
type 8851
number 1 dn 3
number 2 dn 5
number 3 dn 16
presence call-list
dtmf-relay sip-notify
username 103 password 103
codec g711ulaw
video
blf-speed-dial 1 101 label "xxx"
