error xml [5]
fjrubiobarcena
Sometimes when a user performa a corporate directory search from an ip phone gets that message: "error xml [5]". any ideas of the cause?.
Using ccm 4.2(3) - ip phone 7911, 7941, 7961
rajmohan80
Corporate directory search may not be supportd in these ip phones using XML services
jbarcena
Level 9
Level 9
You might be hitting this bug:
CSCse37151: Phone displays XML Parse Error when accessing Contact List
Symptom:
XML Parser Error on phone when element contains 32 characters.
Conditions:
See Symptom
Workaround:
Shorten the length to 31 or less.
I would also recommend you to upgrade to the latest phone load.
//Jorge
Well, this also happens in my deployment. Thanks for the solution.
Wiyandi
