05-08-2014 10:58 AM - edited 03-16-2019 10:43 PM
After upgrading my EX60 from 6.3.1 to 7.1.1 I now receive "Lost connection with control device" and the touch control panel sits in a spinning loop.
I also reveive the following within the web management interface on the EX60:
ERROR: Touch panel connection
If I downgrade back to 6.3.1 it works again. I have already rebooted and factory reset the entire unit and also disconnected and reconnected the touch panel.
Solved! Go to Solution.
05-08-2014 08:10 PM
Have you tried a factory reset of the touch by holding the "!" symbol for 10-15 seconds seconds until it lights up and then pressing "mute" button twice.
Video posted at the following link
https://supportforums.cisco.com/video/11930611/resetting-cisco-telepresence-touch-8-factory-defaults
Manish
05-08-2014 08:10 PM
Manish
05-09-2014 07:32 AM
Thank you, that resolved the issue.
02-27-2015 01:10 PM
I'm having the same error message on an SX80 with no touch panel
We use a Crestron controller so we will never connect a Cisco touch panel... we just want the error message to go away in the diagnostics/troubleshooting web page.
09-25-2016 06:25 PM
Hi Manish,
I know this is a old question, hope you are able to see this.
I'm having the same error message on an MX200.
I tried a factory reset on our touch panel, it did reboot but stuck at the logo page.
Is there anything else I can do to further t-shoot?
The software version is TC7.3.2
Asher
09-25-2016 11:53 PM
Hi Asher,
if the factory reset does not help then you may try downgrading the firmware. If the issue persists you may contact TAC if the device is covered under a contract.
Manish
