04-03-2013 01:45 PM - edited 03-16-2019 04:35 PM
I failed install CUCM 9.1 on VM ESXi 4.1 server. following this link, I have got the install log file.
http://docwiki.cisco.com/wiki/How_to_Dump_Install_Logs_to_the_Serial_Port_of_the_Virtual_Machine
I have followed the instrution and attached a new, empty file to the serial port when dump the install log. but when I open the log file, all of the then are unreadable symbol.
any idea?
Kevin
Solved! Go to Solution.
06-30-2013 03:47 PM
I think you need upgrade CUCM 7.1.5 to 8.5(1)SU5 first. then virtualize CUCM 8.5(1)SU5. last, you can upgrade CUCM 8.5(1)SU5 to CUCM 9.1.
09-05-2013 08:22 PM
I'm hitting the same problem with a bootable 9.1.1.20000-5 .iso on a Unity Connection subscriber install. UCS server is C220M3, using latest 9.1 ova. The same .iso worked fine for a CUCM subscriber install. Will attempt install again with 8.6.2 .iso and perform upgrade.
10-12-2013 10:27 AM
I had the same critical error with bootable 9.1.1.20000-5 when attempting to install the subscriber on C220M3. Here is what worked for me. Go back to the Publisher and reset the cluster password with "set password user security" in the CLI of the Pub. It will ask for the existing pass, then put in the new pass and make note of it. You will then see the message to reset all your nodes for the change to take effect. Cancel it if you are not ready to reset.
After it comes back up, try your install with the sub again.
10-13-2013 01:55 PM
The latest version is UCOS_9.1.2.10000-28.sgn.iso now. Did you try this version?
10-24-2013 01:39 AM
I am attempting to build a CUCM 9.1 server in the lab on a VMWare 5.5 ESXi box. Hardware-wise it should be OK but I am getting the error detailed above. I have tried ALL available 9.1 Bootable ISO's using the 9.1 OVA template and they all fail at the same point. I have just tried 8.6.2.23900-10 with the 8.6 OVA template and again this failed at the same point.
I am beginning to think there is some other issue here?
01-14-2014 06:24 AM
I was try to upgrade CUCM from 8.5.10000 to UCSInstall_UCOS_9.1.2.11900-12.sgn
Now it was stuc on component Install and it has been over 2 hours still the same message ...
Anyone has any idea ???
01-14-2014 07:14 AM
Normally it takes 2-3 hours for complete upgradation.
Are u getting some estimated wait time?
regds,
aman
01-14-2014 07:43 AM
no it has been over 6 hours ...
still the same and open the Cisco TAC ... but the tac not help at all .
have you done this version upgrade before ?
thanks
01-14-2014 07:52 AM
Hi ,
I did from CUCM 7 to 9 but we were able to complete in 2-3 hours.
Just to cross-check did u install ciscocm.refresh_upgrade_v1.3.cop.sgn.I beleive u are upgrading from
8.5.1.10000-26 restricted version .Is that correct?
regds,
aman
01-14-2014 07:54 AM
correct .
01-14-2014 08:12 AM
seems , upgradation has somewhat hanged.
Is this happening on Publisher?
regds,
aman
01-14-2014 08:32 AM
thanks for that .
yes , you right ... it just finished and over 7 hours for finished ...
the hard part is you couldn't see the status upgrade processing from the consol ..
but this CLI maybe will help "
utils system upgrade status
01-14-2014 08:47 AM
So, is it finished now ?
how many phones and servers u have in a cluster ?
regds,
aman
01-14-2014 08:48 AM
over 3000
and 1 x pub 3 x sub 2 x cups
01-14-2014 08:52 AM
upgradation is still going on or finished?
regds,
aman
