For incoming FXO calls auto attendant does not respond to digit entry
Halsser
Hi All,
For incoming FXO calls auto attendant does not respond to digit entry from certain provider, whereas recognize digit entries from other providers normally and the forwarded the entered extension normally.
Call flow:
PSTN caller – FXO – (Router to CUCM sip trunk)-CUCM-(CUCM to CUC sip Trunk)-Unity
What the problem looks like Is it dtmf issue with this certain provider, or misconfiguration please help me how to fix this issue.
7 Replies 7
Jonathan Schulenberg
Just to clarify: are you saying DTMF isn’t recognized for any call on the analog line plugged into that FXO port or only calls originating from a specific carrier?
Thank you for your response.
DTMF isn’t recognized for Only calls originating from a specific carrier.
Halsser
Any suggestions ?
Can you activate a debug ccapi inout , debug voip  dsm dsp and debug voip rtp session named-event and aks someone from a non working provider to make a call?
Then post the output
Carlo
Please rate all helpful posts "The more you help the more you learn"
Halsser
Solved
Halsser
does that mean the failed carrier not sending the DTMF?
hamadalsser222
Any suggestions?
