06-08-2012 11:59 PM - edited 03-16-2019 11:35 AM
0/0/1 g729r8 n S_CONNECT FXOLS_OFFHOOK
0/1/1 g711ulaw n S_CONNECT FXOLS_CONNECT
whats will be the difference between above two since both are connected with different codec.
06-09-2012 12:46 AM
can you add the show run from the gw.
06-09-2012 02:58 AM
trunk group FXO
voice-card 0
dspfarm
dsp services dspfarm
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
sip
bind control source-interface Loopback10
bind media source-interface Loopback10
registrar server
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
voice class h323 1
h225 timeout tcp establish 3
voice iec syslog
voice statistics type iec
ip address 10.5.250.65 255.255.255.192
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.5.250.65
voice-port 0/0/1
trunk-group FXO
supervisory disconnect anytone
no battery-reversal
input gain -3
output attenuation -1
echo-cancel coverage 64
no comfort-noise
cptone SA
timing hookflash-out 50
connection plar 9801
description *** LOCAL LINE ***
music-threshold -45
bearer-cap Speech
caller-id enable
sccp local Loopback10
sccp ccm 10.50.2.4 identifier 2 version 7.0
sccp ccm 10.50.2.3 identifier 1 version 7.0
sccp
sccp ccm group 1
associate ccm 2 priority 1
associate ccm 1 priority 2
associate profile 1 register abcd_CONF
associate profile 2 register abcd_XCODE
associate profile 3 register abcd_MTP
dspfarm profile 2 transcode
codec g729r8
codec g711alaw
codec g711ulaw
maximum sessions 4
associate application SCCP
dspfarm profile 1 conference
codec g729br8
codec g729r8
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
maximum sessions 1
dspfarm profile 3 mtp
codec g711ulaw
maximum sessions software 10
dial-peer voice 10 pots
trunkgroup FXO
tone ringback alert-no-PI
destination-pattern 900.T
fax rate disable
prefix 00
dial-peer voice 205 voip
description To CallManager Pub
destination-pattern 9801$
session target ipv4:10.50.2.3
voice-class codec 1
voice-class h323 1
dtmf-relay h245-alphanumeric
req-qos guaranteed-delay audio
acc-qos guaranteed-delay audio
fax-relay ecm disable
fax rate 14400
fax nsf 000000
fax protocol pass-through g711ulaw
no vad
telephony-service
srst mode auto-provision all
max-ephones 110
max-dn 400
ip source-address 10.5.51.1 port 2000
max-conferences 8 gain -6
transfer-system full-consult
create cnf-files version-stamp 7960 May 27 2012 17:41:04
06-09-2012 05:00 AM
Omerpal,
What exactly do you want to know?
Please rate useful posts
"I am complete in God, God completes me"
06-09-2012 06:53 AM
I want to know that why some FXO ports are in connected state with G.729r ans some with G.711ualaw. Thanks for your info
02-06-2013 02:56 PM
Hello All
i have the same problem, any idea how to resolve this issue?
Alexis
