FXS stay in off-hook
Yangjp715
Level 2
Level 2
Hi All,
I have an issue for fxs port in voice gateway, the fxs port connceted to the fax machine is in off-hook state. it will change to on hook when i unplug the phone cable.
IOS Version : C2951-UNIVERSALK9-M version 15.2(4)M5.
H323 voice gateway.
shut and no shut on voice port, no any changes. please see attached picture.
Can someone please tell whether this is due to any IOS bug?
5 Replies 5
Nadeem Ahmed
Can you post the config of the fxs port and collect these debugs with show command
debug voip vtsp all
debug vpm signal
test voice port x/x/x
sh voice trace x/x/x
do shut and no shut after applying the debug
Br
Nadeem Ahmed
Br, Nadeem Please rate all useful post.
Hi Nadeem,
Thanks for helping.
dial-peer voice 803 pots
 service default
 destination-pattern 803
 port 0/3/1
voice-port 0/3/1
 cptone CA
 station-id name Speaker
 station-id number 803
0/3/1 State Transitions: timestamp (state, event) -> (state, event) ...
926841.224 (FXSLS_ONHOOK, E_DSP_SIG_1100) ->
926841.224 (FXSLS_WAIT_SETUP_ACK, E_DSP_SIG_0100) ->
926841.224 (FXSLS_W_SETUP_ACK_ONHOOK, E_DSP_SIG_1100) ->
926841.224 (FXSLS_W_SETUP_ACK_ONHOOK, E_HTSP_SETUP_ACK) ->
926841.228 (FXSLS_ONHOOK, E_DSP_SIG_1100) ->
926841.228 (FXSLS_GLARE, E_HTSP_RELEASE_REQ) ->
926841.484 (FXSLS_GLARE, E_DSP_SIG_0100) ->
926841.536 (FXSLS_GLARE, E_DSP_SIG_1100) ->
926842.028 (FXSLS_GLARE, E_HTSP_EVENT_TIMER) ->
Now it's status is changed to on-hook, if i enter command " csim start 803" to test, the status will change to off-hook, but when i place a call from jabber to 803, the status is not changed, the status is still on-hook, maybe something is wrong on router?
I captured log on RTMT, please see bellow:
2014/09/13 11:25:53.294|SIPL|0|TCP|IN|192.168.100.11|5060|CSFReceptionist|192.168.100.17|1900|1,100,13,332.56^192.168.100.17^*|6952|000c29c5-26ec0012-00006613-00003489@192.168.100.17|INVITE
2014/09/13
11:25:53.295|SIPL|0|TCP|OUT|192.168.100.11|5060|CSFReceptionist|192.168.100.17|1900|1,100,13,332.56^192.168.100.17^*|6953|000c29c5-26ec0012-00006613-00003489@192.168.100.17|100 Trying
2014/09/13 11:25:53.304|SIPL|21471657|TCP|OUT|192.168.100.11|5060|CSFReceptionist|192.168.100.17|1900|1,100,13,1.836^*^*|6954|000c29c5-26ec0012-00006613-00003489@192.168.100.17|183 Session Progress
2014/09/13 11:26:02.631|SIPL|21471657|TCP|OUT|192.168.100.11|5060|CSFReceptionist|192.168.100.17|1900|1,100,13,305.193^192.168.100.11^ANN_2|6955|000c29c5-26ec0012-00006613-00003489@192.168.100.17|404 Not Found
2014/09/13 11:26:02.632|SIPL|21471657|TCP|IN|192.168.100.11|5060|CSFReceptionist|192.168.100.17|1900|1,100,13,332.57^192.168.100.17^*|6956|000c29c5-26ec0012-00006613-00003489@192.168.100.17|ACK
2014/09/13 11:26:02.633|CC|REJECT|21471657|21471658|221|803|803|1
i user jabber for desktop(221) to call 803, it is rejected.
Any helps would be appreciated.
The status is still like that........, any advice?
Hi all,
I'm on site, the test phone is ring when i plug in cable, shut/no shut, it is same than before, ring and ring, i remembered i enter the command" csim start 802" before, does this case this? how can i stop it?
Thanks.
