Hardware conferencing on 2921 router
navinder.singh
I have configured hardware conferencing on 2921 router, however, it is not getting registered with CUCM version 8.5, I wanted to ask is it mandatory to configure router as MGCP or H.323, is it mandatory to have E1 termination and register the router with CUCM prior to configure conferencing.
Rgds.....Navinder.
mkchandak
No, it is not necessary to use the Router for anything else. You can setup the router to work only as MTP/XCODE/CFB. To look into why it is not registering, a few things to check would be to ensure that you have the sccp profile configured and associated it with the ccm and using the same name on CUCM.
Leonardo Santana
Hello Navinder,
No the H.323 and MGCP are call signaling protocols.
For Hardware CFB, you need resources on your gateway, and apply the correctly configurations on your CUCM and Voice gateway
Take a look on this guides:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a0080334294.shtml
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/8_6_1/ccmsys/a05confb.html#wpxref27448
Leonardo Santana
Rate this if helps!
Leonardo Santana
*** Rate All Helpful Responses***
Chris Deren
Can you post your config and a screen shot of the conference bridge configuration in CUCM?
Chris
