09-18-2014 07:59 AM - edited 03-17-2019 12:12 AM
Hi, I have a 2921 voice gateway running IOS C2900-UNIVERSALK9-M Version 15.3(3)M2.
How can I know how many rules I can define in a voice translation-rule command ?
I know that former, only 15 rules could be defined. Is this always true ?
Thanks for help.
Solved! Go to Solution.
09-18-2014 08:29 AM
I think, Now it is 100 and you can verify the same by putting question mark as below.
Router(config)#voice translation-rule 1
Router(cfg-translation-rule)#rule ?
<It will show the range here>
Suresh
09-18-2014 08:29 AM
Suresh
09-18-2014 09:40 AM
Suresh is correct.
I have a 2921 running 15.3(3)M1 and the output below is taken from it.
CUBETRE-01#conf t
Enter configuration commands, one per line. End with CNTL/Z.
CUBETRE-01(config)#voice translation-rule 1
CUBETRE-01(cfg-translation-rule)#rule ?
<1-100> Translation rule tag
09-13-2015 07:04 AM
I'm using 2821 router that has this Version 12.4(15), it support only 15
CME-(config)#voice translation-rule 666
CME-(cfg-translation-rule)#rule ?
<1-15> Translation rule tag
do i have to upgrade my IOS??
Thanks in advance,
09-14-2015 01:57 AM
Yes you need to upgrade the IOS version 15.x. as i already mentioned in my first response.
it was changed in the IOS version and number of rule has been increased and introduced from 15 to 100 from 15.1(4)M. Prior to that you will see this 15 only.
Br,
Nadeem
09-18-2014 10:42 AM
for more details refer to this document.
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/voice/vcr3/vcr3-cr-book/vcr-r1.html#wp8518966320
Br,
Nadeem Ahmed
