04-25-2014 04:34 AM - edited 03-16-2019 10:34 PM
Hi everybody.
I'd like to know how to configure TAPS in CUCM 8.5 in order to deploy one thousand of phones with BAT.
Shall anybody tell me where I can find a paper to do it step by step?. I'm newby with this service.
Thanks in advance.
04-25-2014 06:57 AM
You can find the instructions here:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/bat/8_5_1/bat-851-cm/t18taps.html
HTH,
Adam
**Please remember to rate helpful posts**
04-28-2014 04:41 AM
Hello.
After reading the whole document I have several doubts:
The following prerequisites apply to TAPS installation for BAT:
Ensure the Cisco UCCX server is configured
Should I have UCCX server?. I have no this server.
You can activate and deactivate TAPS service by using Cisco Unified Communications Manager
Serviceability after you access it by using the appropriate URL. Use the following procedure to activate
the service.
Procedure
Step 1 Access Cisco Unified Communications Manager Serviceability.
Step 2 Choose Tools > Service Activation.
Shall I activate TAPS service on publisher or in suscriber?. I have already running TAPS service in publisher but no in suscriber.
Step 1 In the Cisco Unified Communications Manager Administration window, choose System > Service
Parameters. The Service Parameter Configuration window displays.
Step 2 From the Server drop-down list, choose the appropriate server.
What server?, publisher or suscriber?
Another doubt:
I have a CUCM cluster with two servers: one publisher and a suscriber one. Where should I enable autoregister?, publisher, suscriber or in the whole cluster?.
The whole phones are in registered in the suscriber.
Thanks in advance.
04-28-2014 08:12 AM
>>Yes, unless you are installing CUCM 10, a UCCX server is required for TAPS.
>>The TAPS service will only run on the Publisher
HTH,
Adam
04-28-2014 09:21 AM
Hello
I don't know if I'm understandig well.
I've used TAPS in Cisco Call Manager 4 without UCCX server.
Anybody knows something more about this important change?.
Thanks in advance.
04-28-2014 12:05 PM
You may have not had a dedicated UCCX server when using CCM 4, but you needed a Cisco IP IVR/IP AA server which I believe could run co-resident on the Publisher.
A lot has changed since CCM 4.
HTH,
Adam
**Please remember to rate helpful posts, for the betterment of the community**
04-29-2014 12:05 AM
Thank you Adam
That IVR that you said was built on Cisco Unity.
I have Cisco Unity now. Is it a valid solution to configure TAPS?.
How?
04-29-2014 05:59 AM
Unfortunately Cisco Unity will not work as a replacement for UCCX in regards to TAPS. You must have a UCCX server in order to use TAPS.
HTH,
Adam
04-29-2014 09:31 AM
My colleague and me agree that it sounds very strange, that is compulsory a UCCX server to use TAPS.
However, in the Cisco document that you told me, names UCCX server.
I feel lost.
