IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5954 Views
  • 14 replies
Hey everyone,I'm trying to figure out if my 7941G is dead.  I pulled the phone out today to try and load the SIP software on the phone and have had nothing but problems with it.  It first started with the phone not pulling a dhcp address when I plugg...
I loaded older files on my CERs 8.5 to fix a problem. I cannot restart the subscriber. Even when the publisher was down I could not get the pull down menus on the subscriber to reboot it. Under the Cisco Unified OS Admin I see the   Show, Settings  S...
gp1200x by Level 2
  • 174 Views
  • 1 replies
Hello, regarding how CUCME matches an outbound voip dial peer. Apparently it matches the entire string of digits"en bloc" to match the dial peer.However in Jeremy Ciaora's CCNA Voice book he does a "debug voice dialpeer" which shows the CME router pe...
fran19422 by Level 1
  • 3623 Views
  • 3 replies
Dear All we NEED a solution for transferring.our issue is we want our secretary can transfer the call even before call get connected ( in ring out phase) issue is the transfer softkey will appear after the call is get connected not before thathow can...
User A & User B both have SNR setup for their mobiles. User A calls User B's desk phone from their mobile. User B's phone shows User A's desk number ringing. CallManager then rings User B's phone due to the SNR configuration. The CLI presented to Use...
I have 2 MGCP gateways and each have 1 PRI. These PRIs are under same Route Group. If my primary PRI fails then calls are not routed off of 2nd PRI, but calls routed off of next Route Group which is my backup location.Following Service Parameters are...
dpuranik by Level 1
  • 334 Views
  • 1 replies
