How to determine if I have ICD Enhanced package??
shayonasul
Can anybody suggest any pointers to determine if we have the ICD enhanced package or not? We have IPIVR 3.1(2), not quite sure if it's enhanced or not.
Thanks in advance.
Thats correct.
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
11 Replies 11
thisisshanky
Level 11
Level 11
Its been a while i have worked with the old 3.x systems, but on the About page dont u see the package you have ?
Sankar Nair
Thanks for the quick response. But unfortunately the 'About' page doesn't say anything of that sort. I even tried the 'About' page on CRA Editor without any success.
Your best bet is to either look at the license files, or open the script editor to see if you have the DB steps, also under the rm subsystem see if you can do skill based routing, with standard version you wont see it.
Chris
Chris,
The DBstep is not available in Std and enhanced. So i think the best thing to check is skills based routing. But then did 3.x have skill based routing ?
Sankar Nair
Login to the IPCC express server and go to icd programming.If you just see resource group then it will be standard.
Another way of finiding is open cisco desktop administor and click on workflow.If you just see enterprise option then it is standard version.In enhanced you have more options.
Hope this helps.
R
We are using IPIVR with IPCC Enterprise and hence not using/installed Cisco Desktop Admin. Where do I look for "ICD Programming"? I opened CRA Admin page and it's not under any of the menus.
Well I opened script editor and do see a 'Database' folder under which there are DB Get, DB Read, DB Write & DB Release steps. But under 'subsystems' have only the following > Jtapi, ICM, Database, Http, eMail and Cisco Media.
Opened .lic file in notepad, but it doesn't say there if it's standard/enhanced :(
Sulabh
Well, if you have IP-IVR no IPCC Express then I don't belive there are differnt versions of it.
Chris
In that case, I won't be able to find 'Set Priority' step under any of the folders in my CRA Editor, would this be correct? And since 'set priority' doesn't exist, I wouldn't be able to prioritize a call based on prompt selected.
Please let me know if both of my above assumptions are right?
Sulabh
Can someone please confirm/deny my last post??
Sulabh
Thats correct.
Sankar Nair
