How to find out all extensions that has set call fwd to a specific number?
eddchen
Hi guys,
We have a need to find out all numbers that has set call fwd to a specfic number, is there a way to find it easily from CUCM? we are using version 8.
Dennis Mink
the way to do this is to use BULK Administration in CUCM. got to BULK administration>Phones>Export Phones>All details.
This will create a CSV file,  chuck that into Excell and do a search for the call forward specific number you are interested in.  This will then tell you what extensions and MAC addresses it is active on.
Easy
Please remember to rate useful posts, by clicking on the stars below.
Dennis Mink
Easy
tacl75
or alternatively you can export the phones into csv as well.
Sent from Cisco Technical Support Android App
You can also refer tis URL for running a SQL query provided by Mr. William Bell.
http://www.ucguerrilla.com/2012/04/cucm-sql-queries-listing-call-forward.html
regds,
aman
Ayodeji Okanlawon
You can also use sql query to achieve this..This is the query you need. Just change the number to the number you want. I find this easier that using BAT and exporting all data
run sql select d.name as device,  n.dnorpattern, cfd.cfadestination from device as d inner join  devicenumplanmap as dmap on dmap.fkdevice = d.pkid inner join numplan as n on n.pkid=dmap.fknumplan inner join callforwarddynamic as cfd on cfd.fknumplan=n.pkid where (cfd.cfadestination = '917035551212')
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
