Hi ,
Please help me to take screenshot of the Cisco phone screen.
The enterprise parameter has URL authentication mentioned in IP .It doesn't have a host name.
Have you tried this procedure/URL:
Hi Chris ,
This doesn't work .
OK, what do you get?
Did you check the "troubleshooting" section of the doc?
Hi Chris ,
It comes with page cannot be displayed
Hi there
Most probbaly this could be due to this,
Check your Authentication URL, is it an IP Address or FQDN. Check the DNS resolution for the phone.
Is it a secure URL (i.e. HTTPS) and also check this phone have an ITL issue preventing it from trusting the TVS service.
Hope this helps!
Cheers
Rath!
***Please rate helpful posts***
Hi ,
Its an IP address mentioned in the url authentication.
Hello, I made a tutorial about taking screenshots from Cisco IP Phones, you can check below:
HTH.
