01-05-2015 08:03 AM - edited 03-17-2019 01:29 AM
Hi Guys,
I've done to transfer CDR data to another server (billing server) by using sftp. Now I would like to know how to import these files to SQL Server 2008.
Please advise and appreciate your help.
Tan
01-06-2015 12:12 AM
CDRs are just CSVs, so you need to go ask in a SQL Server forum on how to do this.
NOTE: The CDR format tends to gain fields between CUCM versions (even minor versions) so you should make sure your import process can handle extra/unexpected fields.
GTG
01-06-2015 02:18 AM
CDR is flat file and no extension, do you know what's best third party software for this?
regards,
Tan
01-13-2015 07:12 AM
Variphy has a great CDR solution. There are others out there as well but that was my preferred vendor after looking at other solutions.
