How to input a CUCM extension for a call handler
Yasir@1995
Level 3
Level 3
Dear Team,
I have configured a system call handler in the cisco unity connection, but as per the user requirement,  after the greeting, if the user dials any extension which is configured on CUCM, it should transfer the calls to that extension.
How can I achieve this with the current setup?
We have 2 nodes in CUCM and 1 node in CUC.
On the call handler greeting enable Allow Transfers to Numbers Not Associated with Users or Call Handlers. Make sure CUC restriction table allow forwarding to  the extension which user enter.
Response Signature
7 Replies 7
b.winter
this question has been asked here many times, so you search, you will find a lot of posts with the same question.
E.g. here:
https://community.cisco.com/t5/ip-telephony-and-phones/cisco-unity-connection-8-5-transfer-call-to-non-voicemail-user/td-p/2171362
Thanks for your suggestion, And I found documents in the community.
Response Signature
Hello @Nithin Eluvathingal
Thanks for your response. I have configured the same as you suggested, and now I am able to dial extensions that are not in the Unity database.
Hi Yasir@1995
Now, I have the same issue "i'm not able to transfer the call to CUCM extensions " and I configured CUC handler and CUCM CTI route point, but still cannot transfer the calls.
could you share with me you solutions.
Mahmoud Adel
On your CUC trunk configuration page in CUCM, do you have all three calling search spaces configured?
  • Inbound Calling Search Space
  • Rerouting Calling Search Space
  • Out-Of-Dialog Refer Calling Search Space
All three are required for call exchange between CUCM and CUC.
Also: Double check that your CUC trunk is configured to enable (by checking the box) the "Redirecting Diversion Header Delivery" in both the Inbound and Outbound directions.
Maren
Could you let me know if you verified the restriction table in the CUC?
