11-27-2013 08:56 AM - edited 03-16-2019 08:36 PM
Im trying to export the config file from call manager v8.6 and import it to version 9.1.
I can export it without any errors but once I try to import it to 9.1 it gives me loads of errors.
I'm doing for the whole cucm configuration.
Is it because there are same fields that are different between this two versions?
I was trying to install call manager 8.6, import and then upgrade to 9.1.
Thanks in advance,
Chris
Solved! Go to Solution.
11-27-2013 09:24 AM
I am afraid it does not work that way. Yes, the file structure is quite different.
G.
11-28-2013 07:14 AM
Take a DRS backup of your production system
Install lab as 8.6 in isolated lab as you will need to have the same hostname/ip address
restore from the DRS backup
change hostname and IP address at which point you can put it up on production network
upgrade to 9.1
That's all.
HTH,
Chris
11-27-2013 09:24 AM
G.
11-27-2013 09:27 AM
Ok,
So I have both ISO's. 8.6 and 9.1
If I install 8.6, import the config and then upgrade to 9.1? or the file to do the upgrade to 9.1 is a diffenret one from the brand new installation ISO?
11-27-2013 09:31 AM
Well you must be absolutely sure that the versions of CUCM where you exported and where you want to import to are the same.
Then you can download the upgrade image from cisco.com.
G.
11-27-2013 09:34 AM
Hi Chris.
As Gergely correclty stated, (+5 P G) 9.1 has a quite different structure than 8.6
but if if you import an 8.6 config on another 8.6 than upgrade to 9.1 it should work.
Carlo
11-28-2013 03:57 AM
Thanks guys, will do the 8.6 and then upgrade!
11-28-2013 05:49 AM
May I ask why you are not doing the recommended DRS backup and restore? Why are you going down the import/export route?
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
11-28-2013 07:02 AM
I want to keep the prodution version 8.6 up and running. The 9.1 is just for lab but want to have the same config on it
11-28-2013 07:14 AM
upgrade to 9.1
That's all.
HTH,
Chris
11-28-2013 09:14 AM
My thoughts exactly..Chris..Not sure why people want do import/export config. This is the second time soneone has mentioned it and I find it a little strange..
