IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 6169 Views
  • 14 replies
Hi All,I am in the process of integrating a cucm 9.1 cluster  with a cuc 9.1 cluster. Some confusing points that i hope can be  clarified.for cucm1. I have created one voice mail server with 48 ports that will accomodate both cuc serversfor cucI have...
rramlal by Level 1
  • 443 Views
  • 3 replies
                   All,The below is the configuration on our router and we are using Avaya phones on the network .The phones are not receiving dhcp leases and not working ,can anybody suggest what is causing this issue.Building configuration...Curren...
Hello,we are facing a behavior with SIP third Party devices on cucm 8.6.2aSU3The behavior is that in every call the device use the callmanager as MTP to place the call and the RTP stream is always through the callmanager.We would like that the RTP go...
HiI am trying to configure trusted relay point on a cucm 7 and 9 for Qos Purpose for softphone1)service parameter:Clusterwide Parameters (System - General) sectionFail Call If Trusted Relay Point Allocation Fails: False2) Common Device Configuration ...
Rachel Au by Level 1
  • 438 Views
  • 1 replies
