12-20-2012 02:32 PM - edited 03-16-2019 02:49 PM
I've got an interesting issue that i haven't seen before. We're running CM 8.5.1, LDAP integrated into AD. We're in the process of moving our locations to Cisco IP phones. A user has phones in two locations, one that was recently cut to Cisco and one that is still on Nortel (and is their home location). What is happening, though, is that when people search the directory via the CCMUSER pages, they see his number in the other location. When i pull his account up in CCMADMIN, his telephone number is accurate. I've tried changing his primary extension to <none>, disassociated any devices that have the other number on them, but it seems to be stuck in the directory that the end users use. when i search via the corporate directory on my IP phone, it shows the right number as well...
any ideas on what to do to fix this?
12-20-2012 05:41 PM
primary extension has nothing to do with the number displayed in the directory, it is simply using the telephone number field on ccmuser admin page. Are you saying that that field is different from what you see in the corporate directory? Have you tried brining up the directory on the phone, what does it show?
Chris
12-20-2012 06:11 PM
That's the bizarre thing. When I search via my 9971, it shows the proper info.
08-30-2013 02:17 PM
My experience: When you integrate AD in CUCM, set the phone tab in AD. Otherwise the Phone# does not show in the directory
Good Luck
Mike
08-30-2013 02:25 PM
Sure as the telephoneNumber comes from AD, either telephoneNumber or ipPhone depending on which one you use for the integration.
Chris
