Interconnection CME with Panasonic KX-TDE 600
Chrysostomos_CY
Level 5
Level 5
Hi to all
We have one CME and one Panasonic KX-TDE 600.we need to integrate these PBX via H323 or via SIP protocol
From my site(CME) i have created one dial peer like the below
i think that we this we are ok from our site right?
Do you know anything about Panasonic site?
its asked me A credentials for the sip but we dont use any credential for the sip trunking, dial peer on CME
FOR THE SIP PART
dial-peer voice 19 voip
destination-pattern 1..
session protocol sipv2
session target ipv4:192.168.10.1
dtmf-relay sip-notify
codec g711ulaw
no vad
FOR THE H323 PART
dial-peer voice 21 voip
destination-pattern 1...
dtmf-relay h245-alphanumeric
REGARDS
Please rate all useful posts Regards Chrysostomos ""The Most Successful People Are Those Who Are Good At Plan B""
3 Accepted Solutions
acampbell
Have a look at this link.
http://www.voicesonic.com/panasonic/manuals/KX-TDE_100_200_600/Panasonic-KX-TDE100-200-600-Programming-Virtual-SIP-Card.pdf
There are a few PANASONIC manuaals here - look down to 600 range
http://www.voicesonic.com/customer/Panasonic-115-KX-TDE100-200-Manuals.html
I reckon the Panasonic KX-TDE 600 will be set up as a SIP trunk as if it is connecting to a Service provider and the CME will emulate the SP.
Alex
Regards, Alex. Please rate useful posts.
Cisco CME is sending the requested authentication:
Proxy-Authorization: Digest username="22210960@bbtb.cyta.com.cy",realm="Registered Users",uri="sip:805@192.168.28.8:5060",response="887ec911f9a1c48a968c6ef7df7
After, in one case the PBX sends 'not found', in another, no repsose.
So, the problem is not caused by Cisco CME.
Yea, sure.
On Panasonic I've phone nubmerx 2XX, on CCME - 5XX
Panasonic site (Configuration through PBX UMC)
1) Insert a  V-IPGW16 card in your virtual unit (Item - 1.1)
2) Then go to properties of the system unit (righ click on V-IPGW16)
3) Click on gateway settings
4) Fill all fields in first line (specially - IP address in my config it's - 172.16.0.1 (and remember the number of gateway)). According to my example my gate number - "1"
5) Then click on D2IP and write in first column first nubmer of CISCO CME phone numbers, in my config it's - 5, second column next possible amount of numbers befor "5", my config - "2". And the last column - gate number - according to   item 4) - gate number - "1"
7)Then item 2.6.1 on PBX UMC, choose third tab (numbers of local PBX). And for example in first line, write the first nubmer of phones, that belong to CME, according to my example, it's - 5.
That's all on Pana site
CCME 2901 (A bit easier than Pana)
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729br8
dial-peer voice 1000 voip
destination-pattern 2..
session target ipv4:172.16.0.250
That's all h.323 - established successfully. Hope it will help you, If you have some difficulties, i'll help;)
29 Replies 29
acampbell
Alex
Hi Alex again
we have a tunnel between two sites
from CME site is any special config that we have to do except dial peer?
No as long as the IP routing from the CME to the PAN box is allowed I cant see a tunnel being an issue.
You will need to allow SIP to SIP & H323 internetworking if you have voice mail etc.
voice service voip
And may be SIP authentication along the lines of something like this
sip-ua
authentication username xyz password xyz realm cisco.com
Alex
Hi Alex,
I'm doing the same case.
The issue is like this:
The Panasonic gets a call from the CME and asks for authentication, the CME doesn't sends and and the call is disconnected.
The only option to solve this is to register the Panasonic at the CME.
The CME will act as an SP ( will emulate SP ).
Can you explain me please how to do this?
Thanks a lot.
Here are a couple of links that may help you
http://www.cisco.com/en/US/docs/ios/12_3/sip/configuration/guide/trouble.html
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_configuration_example09186a00808f9666.shtml#
Alex.
It works for me. I added it in CUCM as h323 gateway and it works fine. bothway calls are working fine. I tested it by connecting through CUBE as well. that also works fine. Only the fact is i always considered it as H323 device.
There is no need to register CMe in order to support SIP digest authentication.
Just configure authentication under sip-ua.
Thanks for replies :
Alex, i've looking for, but i've found that the CME has no possiblity to be SIP Proxy.
https://supportforums.cisco.com/thread/92668
Paolo,
See the attached wireshark: when the cisco sends a call to the Panasonic, the Panasonic ask for credentials ( That are configured at the panasonic  ) and the cisco doesn't replies.
How i must set at the dial peer the credentials of this one?
http://www.2shared.com/file/HeKo3BK9/2-CYtoIL.html
Other fact : that same Panasonic is registered to an Asterisk with other Sip trunk and the calls there work bi-directional.
Thanks a lot,
post sip-ua configuration?
Also please do not post wireshark trace for these cases.
Post output of 'debug ccsip message' taken with 'term mon'.
Sorry, have the ccsip trace:
As you will see, the Panasonic is asking for
SIP/2.0 407 Proxy Authentication Required
Where should i configure that for him?
Many Thanks again.
Sent:
INVITE sip:805@192.168.28.8:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.5.5:5060;branch=z9hG4bKBECB191F
From: "PavlosG" <>0911@bbtb.cyta.com.cy>;tag=C2F16A30-1EEB
To: <805>
Date: Mon, 09 Jul 2012 10:36:10 GMT
Call-ID: BBCAD501-C8E811E1-9A6B9574-9CA30A2A@192.168.5.5
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 3131352065-3370652129-2590414196-2627930666
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1341830170
Contact: <0911>
Expires: 60
Allow-Events: telephone-event
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 268
v=0
o=CiscoSystemsSIP-GW-UserAgent 2443 2038 IN IP4 192.168.5.5
s=SIP Call
c=IN IP4 192.168.5.5
t=0 0
m=audio 17260 RTP/AVP 8 101 19
a=rtpmap:8 PCMA/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=rtpmap:19 CN/8000
a=ptime:20
001957: Jul  9 10:36:10.830: //50729/BAA4A4019A66/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
To: sip:805@192.168.28.8
CSeq: 101 INVITE
Content-Length: 0
001958: Jul  9 10:36:10.830: //50729/BAA4A4019A66/SIP/Msg/ccsipDisplayMsg:
Received:
To: sip:805@192.168.28.8;tag=20079
CSeq: 101 INVITE
Allow: INVITE,ACK,CANCEL,BYE,REGISTER
Proxy-Authenticate: Digest realm="Registered Users",nonce="5ab56bd6ac58b061c3870e1c3871e3c6",algorithm=MD5
Content-Length: 0
001959: Jul  9 10:36:10.830: //50729/BAA4A4019A66/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
001960: Jul  9 10:36:10.830: //50729/BAA4A4019A66/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:0, container:8A6B2308
001961: Jul  9 10:36:10.830: //50729/BAA4A4019A66/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:805@192.168.28.8:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
001962: Jul  9 10:36:10.830: //50729/BAA4A4019A66/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 192.168.5.5:5060;branch=z9hG4bKBECC2404
Min-SE:  1800
CSeq: 102 INVITE
Max-Forwards: 70
Contact: <0911>
Expires: 60
Proxy-Authorization: Digest username="22210960@bbtb.cyta.com.cy",realm="Registered Users",uri="sip:805@192.168.28.8:5060",response="887ec911f9a1c48a968c6ef7df702bb8",nonce="5ab56bd6ac58b061c3870e1c3871e3c6",algorithm=MD5
Content-Length: 268
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-16
a=rtpmap:19 CN/8000
a=ptime:20
001963: Jul  9 10:36:11.022: //50729/BAA4A4019A66/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
CSeq: 102 INVITE
Content-Length: 0
001964: Jul  9 10:36:11.022: //50729/BAA4A4019A66/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 404 Not Found
To: sip:805@192.168.28.8;tag=27181
CSeq: 102 INVITE
Content-Length: 0
001965: Jul  9 10:36:11.026: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
001966: Jul  9 10:36:11.026: //50729/BAA4A4019A66/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SPI_EVENT
001967: Jul  9 10:36:11.026: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_SETUP
001968: Jul  9 10:36:11.030: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_DNS_RESOLVE
001969: Jul  9 10:36:11.030: //50730/BAA4A4019A66/SIP/Event/Session-Timer/sipSTSLMain: Event: E_STSL_SESSION_REFRESH_REQ
001970: Jul  9 10:36:11.030: //50730/BAA4A4019A66/SIP/Event/Session-Timer/sipSTSLMain: dir:1, method:102, resp_code:0, container:8A6B36F8
001971: Jul  9 10:36:11.034: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Max-Forwards: 70
CSeq: 102 ACK
Content-Length: 0
001972: Jul  9 10:36:11.034: //50730/BAA4A4019A66/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 192.168.10.253:5060;branch=z9hG4bKBECD1B36
From: "PavlosG" <>0911@bbtb.cyta.com.cy>;tag=C2F16BB4-1564
To: <805>
Date: Mon, 09 Jul 2012 10:36:11 GMT
Call-ID: BC060A82-C8E811E1-9A6D9574-9CA30A2A@192.168.5.5
Min-SE:  1800
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1341830171
Contact: <0911>
Expires: 60
Content-Length: 337
v=0
o=CiscoSystemsSIP-GW-UserAgent 8935 6474 IN IP4 192.168.10.253
s=SIP Call
c=IN IP4 192.168.10.253
t=0 0
m=audio 18790 RTP/AVP 8 0 18 101 19
a=rtpmap:0 PCMU/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=yes
a=fmtp:101 0-16
a=rtpmap:19 CN/8000
001973: Jul  9 10:36:11.134: //50730/BAA4A4019A66/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 183 Session Progress
Via: SIP/2.0/UDP 192.168.10.253:5060;received=10.226.95.253;branch=z9hG4bKBECD1B36
To: <805>;tag=h7g4Esbg_775112800-1341830299740
CSeq: 101 INVITE
Contact:
Record-Route: <10.224.42.132>
Content-Length: 222
Session: Media
P-Early-Media: sendonly
Allow: ACK, BYE, CANCEL, INVITE, OPTIONS, PRACK, REFER, NOTIFY, UPDATE, INFO
v=0
o=BroadWorks 19134227 1 IN IP4 10.224.42.132
s=-
c=IN IP4 10.224.42.7
t=0 0
m=audio 14492 RTP/AVP 8 101
a=fmtp:101 0-15
a=ptime:20
001974: Jul  9 10:36:15.910: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
001975: Jul  9 10:36:15.914: //50730/BAA4A4019A66/SIP/Msg/ccsipDisplayMsg:
Sent:
CANCEL sip:805@192.168.28.8:5060 SIP/2.0
To: <805>
CSeq: 101 CANCEL
Max-Forwards: 70
Timestamp: 1341830175
Reason: Q.850;cause=16
Content-Length: 0
001976: Jul  9 10:36:15.942: //50730/BAA4A4019A66/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 CANCEL
Content-Length: 0
001977: Jul  9 10:36:15.962: //50730/BAA4A4019A66/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 487 Request terminated
CSeq: 101 INVITE
Content-Length: 0
001978: Jul  9 10:36:15.962: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Mmm, now it suprise me.
Where is set :
I guess here:
no dial-peer outbound status-check pots
sip-ua
credentials username 22210960 password 7 XXXXX realm bxx.cyta.com.cy
authentication username 22210960@bbtb.cyta.com.cy password 7 XXXXX
no remote-party-id
retry invite 2
retry register 3
retry options 2
timers expires 60000
timers connect 100
timers register 1000
registrar dns:bbtb.cyta.com.cy expires 110
sip-server dns:bbtb.cyta.com.cy
host-registrar
But where the realm "Registered Users" comes from ? I didn't found it.
Can i set this credentials for each specific dial-peer?
Your help is most valuated for me.
Cisco CME doesn't really give much importance to realm. it will respond anyway with the authentication configured under sip-ua, maybe try configuring the realm anyway.
Unfortunatly is not possible to configure multiple authentication credentials for different DPs. Only a single one under sip-ua.
Hi to all
This tread opened by me
Unfortunately the news are not good
After one month troubleshooting with TAC we didn't manage to solve the problem because the problem with the authentication coming from panasonic
So we have established only incoming calls but not outgoing to panasonic
Sorry guys for the bad news
