IP Communicator for MAC OS X
thejas.ramadas
Hi All
is it possible to install ip communicator or soft phone in a MAC OS X
8 Replies 8
robert49729
You can try to use a emulator such as Parallels -- but the current Cisco solution for Macs is the Cisco Unified Personal Communicator
Brandon Buffin
SJ Labs also makes a softphone that will run on Mac.
http://www.sjlabs.com/
Hope this helps.
Brandon
No mention of that on their website but yes they mention a minimum of $20,000.00 for a business relationship. Gotta love the cents indication of that.
You can download here:
http://www.sjlabs.com/sjp.html
Documentation indicates compatibility with Callmanager.
Brandon
That's a sip softphone. In that area, I believe Counterpath is the leader.
It can run SIP or H.323.
Brandon
Hello- I know this is a really old post but I'm looking for an IP communicator that is compatible with call manager to install on a mac. www.sjlabs is no longer active. Do you have any current recommendations aside from emulators such as parallels or vmware fusion.
Thank you
Use Jabber
java
if this helps, please rate
