IP comunicator for Linux
hi,
Our Client having some of the system with Linux operating system and they want to install IP communicator and VT Advantage on Linux system.
but i think for linux there is no software avalable in Cisco ?
If it is please let me know ..I really want ..Our client Is very serious about that..
Please clear me ...
9 Replies 9
Aaron Harrison
Neither of those products is available for Linux.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
htluo
Level 9
Level 9
Not right now.  But it's on the roadmap.  CSF based client will be available on multi-platforms like, windows, mac os, linux, symbian, blackberry, win mobile, android, etc.
http://htluo.blogspot.com/2010/03/client-convergence.html
Michael
James Hawkins
Level 8
Level 8
Whilst you are waiting for the official Cisco product to be released you could look at using something such as X-Liteas a |Linux softphone.
There is a guide to doing this at the link below:
http://www.netcraftsmen.net/resources/blogs/sip-endpoints-in-cisco-cucm-x-lite-as-an-example.html
It was written by William Bell who posts on here.
Hi Jayesh
Did you manage to Find any CIPC for Linux
shameer
There's no CIPC for Linux
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Hi Jaime
Thanks for the prompt reply. Some of the Support staff uses Linux PCs
is there any alternatives for this to go with CallManger 8.6
shameer
Find a SIP softphone for Linux, and register it as a SIP 3rd party endpoint
java
java
I haven't been able to get them running in wine or crossover either.  It seems like the physical hardware access (headset for cipc and camera for cuva) is the issue.  VMware is your best bet.
Thanks Jamie
can you please recommend any SIP softphone for Linux on CUCM 8.6.
shameer
