03-16-2019 07:15 AM
if a ip phone is not getting ip address
what r the steps to be taken for troubleshooting
Solved! Go to Solution.
03-17-2019 01:04 AM
03-16-2019 08:15 AM
Hi syednoushadali492@gmail.com ,
Check this link:
Remember to mark the correct answers as solved, since that helps other users with similar doubts
03-16-2019 03:37 PM - edited 03-16-2019 04:39 PM
This goes step by step diagnosis : (any other phones working in the same switch)
1. Once you connected the Phone, do you see PoE got Power and Phone ON.
2. If Phone is ON, Do you have switch port configured right VLAN for voice(may be yourcase)
3. where is the DHCP Server ( do you vlan interface with DHCP relay / helper config where the DHCP Server Located)
4. is this only Phone having issue, or any other phones working in the same switch.?
post us the switch config, tell us your DHCP Server IP address ? what IP you expect for the IP Phone s?
03-16-2019 04:20 PM
03-17-2019 01:04 AM
