Voice Gateway
sourajit01
1. What are the functions of the loopback interface in voice gateways?
2. Since loopback interface is always up unless the router is broken, is it advisable to tie the interface which generates H323  traffic to the loopback interface?
balaji.bandi
The loopback interface is a virtual interface that is always up and available after it has been configured.
It not adivse to use Loopback interface for any Data Traffic as best practice. end the loopback again need to use other interface  source to in and out for traffic.
BB
Thank you Balaji, could you please tell me then what is the use of loopback interface in a voice gateway?
it all depends on your network and how you configured, as per standard loopback interface meant to use for :
https://en.wikipedia.org/wiki/Loopback
BB
HARIS_HUSSAIN
You can Tie the H323 traffic to Loopback Interface as well.
*** Please rate helpful post; Mark "Accept as a Solution" if applicable
Haris
