ā05-06-2013 11:49 PM - last edited on ā03-25-2019 08:22 PM by ciscomoderator
Hi Experts,
From the 8945 IP Phone datsheet I see that it requires release 7.1.5 or later.
Can I apply some sort of patch or COP file on cucm 7.1.3 to make 8945 register, without upgrading the call manager?
Please help!
Nirmal Joshi
Solved! Go to Solution.
ā05-12-2013 01:15 PM
You cannot use the 8945 before 7.1(5). They will need to upgrade CUCM or order different phones.
Aman-
You can upgrade to Unrestricted version 7.1.5.35900-7 without applying any licenses.
Unless they are in Iran, Cuba, or another US-export restricted country, they should NEVER EVER upgrade to an Unrestricted version. This is a serious mistake which will permanently disable product functionality (e.g. Phone VPN). There is no way to undo this conversion short of starting over from scratch. Please do not suggest this!
Please remember to rate helpful responses and identify helpful or correct answers.
Message was edited by: Jonathan Schulenberg to correct minimum stated version.
ā05-06-2013 11:57 PM
Hi Nirmal,
You won't be able to make 8945 work like this.
You need to do minor upgrade .You can upgrade to Unrestricted version 7.1.5.35900-7 without applying any licenses.
please refer software compatibility matrix .
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr1.pdf
Prior to doing upgrade , take backup of Call manager.
regds,
aman
regds,
aman
ā05-07-2013 12:05 AM
I can not upgrade at this time as the client has a Global policy to upgrade the call manager clusters worldwide at the same time. They will be upgrading the telephony infra after 3 or 4 months.
I am trying to upsell 8945 ip phones but the challange is that they are on release 7.1.3 at this time.
Upgrade is not possible at this time.
don't we have any cop file or some workaround to make it work?
Nirmal
ā05-07-2013 02:06 AM
Hi Nirmal,
As far as I know , u need to adhere to compatibility.
regds,
aman
Aman-
ā05-12-2013 09:37 PM
Jonathan,
I believe you you mean 7.1.5 not 7.1(3). If 8945 are really supported on 7.1(3), then please point me to the document.
Nirmal Joshi
ā05-13-2013 09:32 AM
Yes sorry. Corrected.
ā05-13-2013 09:39 AM
Jonathan,
Thanks for the confirmation and keep doing the good work
BR,
Nirmal
