08-17-2007 09:35 PM - edited 03-14-2019 11:07 PM
Hi all,
I have a Cisco 2821 router with VWIC2-2MFT-E1/T1 to connect to PSTN via E1 PRI. I think that all the configurations are OK (as I had done a case before and the configurations are the same) but Layer 2 cannot go to MULTIFRAME_ESTABLISHED.
Could anyone give me some explains or instructions.
Thanks and regards,
hoanghiep
The configurations:
card type e1 0 0
no aaa new-model
resource policy
network-clock-participate wic 0
isdn switch-type primary-net5
voice-card 0
no dspfarm
controller E1 0/0/0
framing NO-CRC4
pri-group timeslots 1-24 ##I have also 8 FXO ports so there're enough DSP for only 24 timeslots### (same thing for the already-running-system I mentioned above)
interface Serial0/0/0:15
no ip address
encapsulation ppp
isdn incoming-voice voice
keepalive 10 3
no cdp enable
show isdn status
Global ISDN Switchtype = primary-net5
ISDN Serial0/0/0:15 interface
dsl 0, interface ISDN Switchtype = primary-net5
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = AWAITING_ESTABLISHMENT
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0x80FF7FFF
Number of L2 Discards = 0, L2 Session ID = 190
debug isdn q921
*Aug 18 04:57:26.575: ISDN Se0/0/0:15 Q921: L2_EstablishDataLink: sending SABME
*Aug 18 04:57:26.575: ISDN Se0/0/0:15 Q921: User TX -> SABMEp sapi=0 tei=0
*Aug 18 04:57:27.575: ISDN Se0/0/0:15 Q921: User TX -> SABMEp sapi=0 tei=0
*Aug 18 04:57:28.575: ISDN Se0/0/0:15 Q921: User TX -> SABMEp sapi=0 tei=0
*Aug 18 04:57:29.575: ISDN Se0/0/0:15 Q921: User TX -> SABMEp sapi=0 tei=0
08-18-2007 12:11 AM
i think u have to check from Telco side to make sure ur PRI is ready and activated from their side.
i had like this before and it was a Telco issue.
hth
/majdi
08-20-2007 01:39 AM
Hello
Have you tried changing the CRC4 in the framing - in the UK we use CRC4.
08-21-2007 12:27 PM
is this MGCP gateway?, if so do you have the full config?
Ajaz
08-21-2007 07:52 PM
Put 'encapsulation hdlc' instead of the encapsulation ppp you have, reload and you should be fine.
HTH, Avner.
08-23-2007 05:38 AM
I think the linecode command is missing in controller E1
