02-10-2020 12:02 PM
I've never noticed the "Lower your voice Alert". A user happened to find it. You can turn it off via the phone settings. I am trying to find out if it can be globally turned off. Also, when was this feature implemented. Not finding anything in Administration/Maintain & Operate. Also poked around phone configuration, common phone profiles, enterprise settings.
Solved! Go to Solution.
02-10-2020 08:50 PM
It was introduced on FW 12.7(1), the RN cover it.
02-10-2020 01:26 PM
02-10-2020 08:50 PM
02-11-2020 05:08 AM
Ah yes, release notes. Did not look there. Thank you.
02-12-2020 08:17 AM
Check out the new 12.7 features in the ciscolive doc or release notes. The feature can be disabled.
https://www.ciscolive.com/c/dam/r/ciscolive/emea/docs/2020/pdf/BRKUCC-2050.pdf
02-13-2020 04:47 AM
Thank you for sharing this.
02-13-2020 02:38 PM
FYI, I just saw confirmation this is not centrally managed, this is a PER device setting with no control from CUCM.
If you wish to see this to be centrally managed, reach out to your SE/AM to submit a PER
02-17-2020 08:38 AM
02-17-2020 08:50 AM
There's an enhancement request to disable it by default, that will probably be the fix that comes first
CP-88xx - Make 'Lower Your Voice Alert' Disabled By Default
CSCvt04894
02-17-2020 12:15 PM
Good to know, Jaime. We never know for sure how Cisco prioritizes things. Thanks!
