<Urgent> BAT VG224 DN issue !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
zhangjianping
Hi, anyone who can give me a Export txt file for adding VG224 DN or how to BAT this goal.
I have add 10 VG224 into CCM (5.1), now I need to add some DN on VG224 through BAT, but i always failed though I have tried many way .
Could u pls give me some help? or share me the TXT.
Urgent!!!
Only thing to do avoid doing it all manually is to upgrade to 6. Make sure you go to 6.1.2 though, as there are a number of annoying bugs with VG224/BAT in 6.1.1
Cheers,
Alistair
6 Replies 6
Marwan ALshawi
i think its suported on V6 not 5 !
I don't believe the BAT import of VG224 DN's is supported on 5 or 6 to be honest (248's are), it sounds like it's going to be a painfully slow manual process.
Rob Huffman
Hi Zhang,
Marwan is most correct (nice!)+ 5 points for this Marwan :)
This is not supported in "older" CCM Versions;
CSCeg88823
Symptom:
BAT does not support adding VG224 ports in bulk
Conditions:
This is for all versions of BAT and all current version of Callmanager 3.x, 4.x, 5.x
It is now supported in CCM 6.x
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/bat/6_0_1/t08gwins.html#wp1345635
Hope this helps!
Rob
thanks rob :) and 5 from me for the detailed info as well
Thanks all, each one 5 points.
My god, how can i handle this so many fax manually??????
Cheers,
Alistair
