â01-21-2013 11:00 PM - edited â03-16-2019 03:17 PM
Hello.
My question is simple.
I have an existing route pattern.
Can I make add the # (
that indicates end of dialing sequence) at the end as an option
The idea is to avoid copying the same route pattern and duplicate..
BR
Davi
Solved! Go to Solution.
â01-22-2013 04:56 PM
Davi,
This can be done, if I am getting your question correctly. I have been using this for variable route patterns instead of creating duplicate route patterns, works very well.
For example:
For 9.011! Route pattern, instead of creating two route patterns 9.011! and 9.011!# - You can create one route pattern 9.011![0-9#]. This will make # as optional. If you enter # after the number it will dial the number correctly. If you dont enter the # then it will just wait for t302/interdigit timer to expire and route the pattern as per normal.
So just add [0-9#] after !. This way it will route anything ending with 0-9 or #.
Examples:
9.! -> can be created as 9.![0-9#]
9.011! -> 9.011![0-9#]
Terry
â01-22-2013 07:33 AM
According to the docs, it's not possible.
"The question mark (?) wildcard matches zero or more occurrences of the preceding digit or wildcard value."
...but the notes for # state:
"Ensure the # character is the last character in the pattern."
â01-22-2013 07:47 AM
Like Will said, it's not posible, you will need to duplicate the router pattern to make it work as a option.
Please rate all useful posts
_____________________________
LinkedIn Profile: do.linkedin.com/in/leosalcie
MDGDP, CCNA, CCNA Voice certified
â01-22-2013 08:00 AM
You could do that with a route filter.
HTH,
Chris
Davi,
For example:
Examples:
Terry
â01-22-2013 05:24 PM
I learned something new today . Terry (5).
Favor calificar todos las respuestas Ăștiles.
â01-23-2013 02:24 AM
Thanks Leo!
Davi - Please let us know if you have any further questions on this. If this resolves your query please mark the thread as answered.
Terry
â01-23-2013 02:31 AM
Thank you Terry.
I have tested and it works.
Thanks for the kind help.
Cheers
