ā06-27-2013 10:34 AM - edited ā03-16-2019 06:07 PM
Hey Guys,
I know that CUC 8.6(1) states that you shouldn't install more than 5 locales, but I need to add a couple of more than that to my CUC 8.6(2). Can anyone tell me if the limit increased in any 8.6(2) version or in any 9.x version. If not, has anyone attempted to add more than 5 and what happened?
Solved! Go to Solution.
ā06-27-2013 11:05 AM
Hi Perry,
The recommendations have not changed between 8.x and 9.x. Here
is the 8.x info;
Note Languages are not licensed, and Connection 8.x does not enforce a limit on the number of languages you can install and use. However, the more languages you install, the less hard-disk space is available for storing voice messages. In the Cisco Unity Connection 8.x Supported Platforms List (http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/supported_platforms/8xcucspl.html), information on the number of minutes of storage available on each server assumes that you have installed no more than five languages.
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/requirements/8xcucsysreqs.html#wp512975
And for 9.x;
Note Languages are not licensed, and Connection 9.x does not enforce a limit on the number of languages you can install and use. However, the more languages you install, the less hard-disk space is available for storing voice messages. In the Cisco Unity Connection 9.x Supported Platforms List (http://www.cisco.com/en/US/docs/voice_ip_comm/connection/9x/supported_platforms/9xcucspl.html), information on the number of minutes of storage available on each server assumes that you have installed no more than five languages.
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/9x/requirements/9xcucsysreqs.html#wp574838
Cheers!
Rob
"I don't know how, I don't know when
But you and I will meet again "
- Tom Petty
Hi Perry,
is the 8.x info;
And for 9.x;
Cheers!
Rob
- Tom Petty
ā06-27-2013 11:14 AM
Rob, that was exactly what I needed.
Thank You Very Much!!!!
ā06-27-2013 01:41 PM
Hi Perry,
You are always welcome my friend
Cheers!
Rob
- Tom Petty
