06-15-2012 07:05 AM - edited 03-16-2019 11:41 AM
Hello!
There is a Hunt Group with a couple of phone in it. Wenever a Call comes in and someone takes it, all other phones in this hunt group get a missed call message in there displays. Thats confusing for the users, because they think that no one took the call over. Is there a way to disable it?
Solved! Go to Solution.
06-15-2012 08:04 AM
Rene,
Anytime a call hits the display on
an IP Phone it is saved/displayed as a "Missed" call. There is no way to change this behaviour.
The thread below discussed this in detail and also suggested that the only work around is to use shared lines
https://supportforums.cisco.com/thread/344971
If you dont want to use shared lines you may consider using a different algorithm other than broadcast.
Please rate useful posts
"For the love of God is broader than the measure of man's mind And the heart of the Eternal is most wonderfully kind"
06-15-2012 07:18 AM
Btw. its a broadcast huntgroup, and its callmanager version 8.6
06-15-2012 08:04 AM
Rene,
12-16-2016 06:44 AM
Has Cisco released any update to allow this functionality within the past 5 years? Seems to be a common request/problem...
07-11-2018 12:22 AM
on the user line settings you can uncheck "log missed call" box
