04-15-2017 01:42 PM - edited 03-17-2019 10:04 AM
is there any way to make special button at phone to monitor PSTN FXO line under CUCM 11.X
same as CME configuration .
dial-peer voice 8000 pots
description ** Land Line 1 **
destination-pattern 9000
direct-inward-dial
port 0/0/0
forward-digits all
no sip-register
ephone-dn 100 dual-line
ring internal primary
number 800
label Land Line 1
no huntstop
trunk 9000 transfer-timeout 40 monitor-port 0/0/0
04-15-2017 11:49 PM
We can monitor the Trunk utilization in RTMT, but I think CUCM doesn't have such functionality yet.
Please rate and mark correct posts<<
04-16-2017 07:48 AM
Frankly it's strange if this not available at CUCM !!
04-28-2018 02:08 AM - edited 04-28-2018 02:11 AM
This reply might look very late but just wanted to participate as I had a similar scenario on cucm 11.
in my case I have used a deducted extension that the FXO port are forwarded to it using the h323 connection plar opx xxxx, and using subscription enabled with appropriate calling search space, you will now have the ability to check the FXO port availability such as any extension, and you can have this extension shared line.
If you reached to a better solution, kindly share with me yours :)
