06-05-2012 03:11 AM - edited 03-16-2019 11:30 AM
Hello, gents.
I need you help and advise
I've got a CUCM 7.1.5 + a inbound call from PSTN to my Cisco 7940 phone.
Goes to Status-Network Statistics ( of double click at " ? " button) I've seen a MOS LQK count = 2. When I transfer this call to the Cisco 7942 the MSQ LQK count = 4.5. Transfer back to Cisco 7940 again have a count = 2.
All phones worked with a SCCP and MSQ ver 0.95 + the same codec g729.
Default CUCM software :
Cisco 7940 SCCP P003080200
Cisco 7942 SCCP SCCP42.9-1-1SR1S
As ar as I know MOS-LQK metrics—Use a numeric score to estimate the relative voice listening quality. The Cisco Unified IP Phone calculates the mean opinion score (MOS) for listening quality (LQK) based audible concealment events due to frame loss in the preceding 8 seconds, and includes perceptual weighting factors such as codec type and frame size.
Any Ideas ? Why the MSO is diferent in the same callflow at 7940 -7942 ?
06-05-2012 04:50 AM
Without knowing if there's a specific bug in the MSO calculations on the phones, I'd start by wiresharking both phones and seeing if there really is a difference in the packets on the wire.
GTG
06-05-2012 04:58 AM
Hello, Gordon.
Do you mean to use a utils network capture file
06-05-2012 05:19 AM
That might not work - it depends on the RTP flow. (e.g. using MTPs, etc) Also, I don't trust a device involved in a network conversation to accurately capture the traffic. (Yes, I'm looking at you ASAs !!!)
I always prefer to capture the traffic from outside the device. So I'd port mirror the phone (port span in Cisco speak) and capture the traffic that way.
GTG
06-05-2012 05:26 AM
I see. To create a SPAN port and captured a trafic for analize.
Thanks for advise. I will try
06-05-2012 11:37 AM
Beside whatever call quality the phone indicates, is there an actual issue in quality, are users complaining?
Because if there isn't, you may end up chasing a cosmetic, non-service affecting issue.
