Multicast MOH Question
mattiep00
Hi Guys,
I am recieving silence when placing users on hold. MOH is multicast using CUCM 7.1 and file stored locally on router. Config is as follows:
ccm-manager music-on-hold
call-manager-fallback
moh moh.ulaw.wav
multicast moh 239.1.1.1 port 16544
#sh ephone summ
Max 30, Registered 0, Unregistered 0, Deceased 0, Sockets 0
ephone_send_packet process switched 0
Max Conferences 8 with 0 active (8 allowed)
Skinny Music On Hold Status
Active MOH clients 0 (max 196), Media Clients 0, B-ACD Clients 0
File NZOct2010.ulaw.wav type WAVE Media_Payload_G711Ulaw64k  160 bytes
Moh multicast on 239.1.1.1 port 16544 via 192.168.56.1
#show ccm-manager music-on-hold
Current active multicast sessions : 1
Multicast       RTP port   Packets       Call   Codec    Incoming
Address         number     in/out        id              Interface
239.1.1.1         16544   0/0          42   G.711ulaw
The packets do not increment while the call is on hold.
Can anyone assist? Thanks
10 Replies 10
john.nield
you have NOT activated SRST function yet, add the following commands to the router to start the SRST process required to support MOH on the router:
ephone-dn 1
ephone 1
ip source-address X.X.X.X <--an ip address of the router to bind the SRST app to.
this should fix you problem.
regards
John
mattiep00
Yes, call-manager-fallback has been enabled:
secondary-dialtone 0
max-conferences 8 gain -6
transfer-system full-consult
timeouts interdigit 5
ip source-address 192.168.56.1 port 2000
max-ephones 30
max-dn 48
transfer-pattern 3...
transfer-pattern 91..
keepalive 10
default-destination 9199
no huntstop
call-forward pattern .T
moh moh.ulaw.wav
time-format 24
date-format dd-mm-yy
I see from the show ephone output that the current active MoH file is NZOct2010.ulaw.wav whereas the file specified under call-manager-fallback is moh moh.ulaw.wav. Please change the filename to match exactly the one which you are streaming from the router flash.
moh NZOct2010.ulaw.wav ----->use this instead
Have you enabled multicast routing in your router? You should have the following two commands
ip multicast-routing------>global config mode
ip pim sparse-dense-mode------->under all the exit interfaces through which the MoH has to be streamed.
Also in multicast moh 239.1.1.1 port 16544 add the route command also.
multicast moh 239.1.1.1 port 16544 route 192.168.56.1
What is the MoH server configuration at the CUCM? Is it increment by IP address or port number? Which multicast MoH source id are you trying to play from the CUCM since the IP and port at the router and the CUCM should match for the MoH to work properly.
For PSTN users to listen to MoH you will have to stream it out the loopback interface.
Take a look at the following doc which may help you
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/4x/42moh.html#wp1043892
Troubleshoot
Do a debug ephone moh and check if router is streaming MOH:
R2#deb ephone moh
Jun 28 23:07:43.299: MoH route If Loopback0 46 10.10.110.2 via 10.10.110.2
Jun 28 23:07:43.299: MoH route If Vlan240 ETHERNET 10.10.201.1 via ARP
R2#
Jun 28 23:07:48.747: MoH route If Loopback0 46 10.10.110.2 via 10.10.110.2
Jun 28 23:07:48.747: MoH route If Vlan240 ETHERNET 10.10.201.1 via ARP
R2#
Jun 28 23:07:50.551: ifs_read flash:music-on-hold.au end of file at 490557 read 5964 = 496521
Jun 28 23:07:50.555: moh tail fill from 24 at 0x4A73816C length 2036
Also you can check the multicast Interface 239.1.1.1 status by using following command:
R2#sh ip mroute
IP Multicast Routing Table
Flags: D – Dense, S – Sparse, B – Bidir Group, s – SSM Group, C – Connected,
L – Local, P – Pruned, R – RP-bit set, F – Register flag,
T – SPT-bit set, J – Join SPT, M – MSDP created entry,
X – Proxy Join Timer Running, A – Candidate for MSDP Advertisement,
U – URD, I – Received Source Specific Host Report,
Z – Multicast Tunnel, z – MDT-data group sender,
Y – Joined MDT-data group, y – Sending to MDT-data group,
V – RD & Vector, v – Vector
Outgoing interface flags: H – Hardware switched, A – Assert winner
Timers: Uptime/Expires
Interface state: Interface, Next-Hop or VCD, State/Mode
(*, 239.1.1.1), 00:01:01/00:01:59, RP 0.0.0.0, flags: DCL
Incoming interface: Null, RPF nbr 0.0.0.0
Outgoing interface list:
Vlan240, Forward/Sparse-Dense, 00:01:01/00:00:00
Hope that helps
regards
Nitesh
PS:Pl rate helpful posts
Why multicast moh 239.1.1.1 port 16544? port 16544?
What codec is this?. Which audio source?
dijohn
Does the file-name "NZOct2010.ulaw.wav"  really matter?
How does the phone know whats the filename?
All it knows is what is the Multicast address it needs to listen to.
PS: Rate useful posts
Shouldn't the router need to know what MoH file to stream? If the router has multiple audio files in its flash and we want to enable only 1 file for multicast MoH, shouldn't we specify the exact filename in that command?
Not too sure on that though. Never tried using a wrong filename. Can check that up
Nitesh
Sorry, the filename is a typo on my behalf - they are the same.
However, this router has no loopback interface. I was under the impression if there was no loopback, it would use the configuerd ip source under the callmanager-fallback?
When I debug ephone moh I only get the gig interface with MoH IF response.
And when I do sh ip mroute, there is no entry for 239.1.1.1...
Is multicasting enabled in you router? post a show run of your router. also attach a scrrenshot of the moh server config in the cucm. which audio source are you trying to use? incrementing by port or ip address?
regards
Nitesh
P.S:rate helpful posts
Did you fix this issue, if yes could you please tell me how?
Shahzad
I read your post too fast :)... Yeah..i was under the impression that
CUCM File name and Router File name has to be the same :). That is not
the case here.
anyways... Check the port numbers?. What codec?. What Source Number on
the CUCM?.
I would say
multicast moh 239.1.1.1 port X route
Whats the codec between the Phone and the MOH server?.
Usually MOH server region to any other region usually is configured as
G711. There's Then if its the first source on the CUCM then
just use
multicast moh 239.1.1.1 port 16384 route 14.160.122.11
if 14.160.122.11 is my Voice VLAN interface on the Router.
Just follow this table...Table 1
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_feature_guide09186a00802d1c31.html#wp1089886
PS:Rate useful posts
