Multiple holds on one line
hutto.txed.net
I have a receptionist that has one line available to receive calls.  When she gets a call and a second one comes in, she is able to place the first call on hold and pick up the second call.  What she wants to do is place the second call on hold and go back to the first call, complete it and go back to the second call on hold.  She has a 7960 phone and we are using SCCP, how would I configure the phone to do this, or can it do this already and we just don't know how to do it.  I am running System version: 7.1.5.33900-10
When you put on hold the second call, did you try to use central cursor (that with two arrows up and down)?
If you use the up arrow you should see the first call highlighted and than you can presse "resume" softkey.
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi Maximo.
When she answers to the second call, the first is automaticaly placed on hold. Then she can put on hold the second call and go back with the central cursor to the first call and unhold it.
Carlo
I tried it and i can see that when i pick up the second call that it does indeed put the first call on hold.  The problem is I don't know how to pick up the first line.  What I see is when I put the second call on hold, The display shows both calls on hold with a number 1 and 2, when i try to resume the first call it keeps picking up the second call, how do I resume the first call?
Carlo
Jaime Valencia
Configure the maximum number of calls accordingly.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
