Mwi not working in uc 8.5 version over sip integration with cucm
owaisqadri
Hi all,
After sucessfully intergration of uc with cucm using sip. After making a test call from phone a to phone b . Phone a send the voice msg to phone b, but phone b has no mwi indicator & no msg notification icon also , but when I press msg button on phone b I can hear that there is new msg available. If any one has encourted this problem plz help
7 Replies 7
Chris Deren
Does the CSS assigned to the SIP trunk list Parition of the phones?
Do you have any ports on UCON used by this integration configured for MWI?
Chris
I have the exact same problem,
I double checked the CSS under Sip Trunk and all ports are configured for MWI
Thanks in advance
Are all the CUCM servers referenced under the port group in Unity Connection?
How many CUCM servers do you have in the environment?
Have you tried resynchying MWI?  How about restarting notifier service?
Chris
Hi Chris,
Thank you for your answer.
I have a 3 server CUCM Cluster and all of them are referenced under port group.
I already resynched the MWI , restarted the notifier service on the UCON Publisher ( I cannot restart it on the subscriber. I guess it's normal) . I also restarted the entire UCON cluster but no success.
Can you check that on your sip trunk security profile used for unity connection integration, you have
System>Security  > SIP Trunk Security Profile
The ff: checked
1. Accept out-of-dialog refer
2. Accept unsolicited notification
3. Accep replaces header
You can look in here for detailed explanation fo how to setup the SIP trunk integration..
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/7x/integration/cucm_sip/guide/cucintcucmsippdf.pdf
Please rate useful posts
"For the love of God is broader than the measure of man's mind And the heart of the Eternal is most wonderfully kind"
Please rate all useful posts
Thank you aoklawon, adding parameters to the security profile work for me.
Romain
Glad to know it helped you..Please dont forget to rate posts!
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
