06-16-2013 06:03 PM - edited 03-16-2019 05:54 PM
Hello !
I would like to use my 2811 router as a CUCM voice gateway (MGCP), What module would I need to get as a minimum ?
Does a VWIC2-1MFT-T1/E1 work ? - as per the Cisco web site, it should, but do I need to add DSPto the router to make the voice work ?
Thank you.
06-17-2013 12:11 AM
yes the VWIC2-1MFT-T1/E1 will work. Remember that you'll need at PVDM Module. Size can be determined by dsp calculator:
http://www.cisco.com/web/applicat/dsprecal/dsp_calc.html
Also minimum IOS version of 12.3(14)T for the VWIC card.
regards
Marc
06-17-2013 07:00 AM
Already discussed in another thread, please do no open duplicates.
06-17-2013 12:43 PM
This is because the 2 first one took 1 hr to show up, I though they were lost in the system,
Thanks Marc for your help.
06-17-2013 01:03 PM
You did not say what type of PSTN connection you have, that card will work for PRI, T1/E1, if that is what you have then along with PVDMs you will be good. If on the other hand you have POTS lines then you need FXO card, or analog DID lines require FXS/DID card. For SIP trunk you do not need any cards.
Chris
