System version: 7.1.3.32900-4
Hello
We have recently setup a h.323 gateway to a remote site and calls are flowing to/from the remote site via the WAN. I have now attempted to setup AAR however this doesn't work, Can you help?
I am setting the remote location audio bandwidth to 1 to simlate the test. When i make the test call i get the following error "not enough bandwidth"
i have done the following config as per the instruction i have understood from Cisco
1. Enabled Automated Alternate Routing Enable to true in service parameters
2. created the locations (UK & US)
3. created the aar_css for PSTN access
4. created the aar groups with the pstn dialling rule
5. added the UK phone to the UK AAR Group and given the AAR CSS access to the PSTN
6. added the line 1 (in a udp) to the UK AAR Group.
7. added the US aar group to the remote h.323 gateway
Is there anything i am missing? i can supply more detail if it helps?
Thanks in advance
C.
Solved! Go to Solution.
Yes AAR is only supported between phones registered to the same CUCM. Yes AAR will only work with cisco devices. The decisions are made as you can see based on information obtained from the calling and called destination devices. If cucm is not aware, it cant invoke AAR
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
One tip is to make sure you apply the AAR group to the line, not the device. The device level AAR group setting is only used for device mobility (roaming). You have to have the AAR group configured on the line for AAR to be invoked when in a not enough bandwidth scneario.
Hello Joe and thank you for the reply
i do have the aar config applied to the line as well as to the phone. We use EM so the line exists on the udp
AAR Destination Mask = blank
AAR Group = UK_Cluster_AAR
Retain this destination in the call forwarding history = ticked
Is there anything else i can check?
C.
I should add that the phone just displays not enough bandwidth. It doesn't seem to even attempt to re-route the call.
Click,
Here are the steps to enable AAR.
Check through the lines and see which you are missing. Do you have External number mask configured on the Destination phone?
See my comments above. I guess the first question/response would be is AAR only support on cisco cucms/ single clusters? as stated above. the HQ is using a cucm cluster and the remote end is a 3rd party h.323 gateway connected to an analogue pbx
Thank you for the answer. I will need to seek other ways to redirect calls via the PSTN. Thank you
Click,
If I follow the scenario correctly then you have a H323 Gateway configured in CUCM that points to your remote IP-PBX / Phone. If that is the case then you can do the following:
Put H323 GW into a Route Group (e.g. h323_rg)
Put one of your pstn gateways into a Route Group (e.g. pstn_rg)
Put h323_rg and pstn_rg into a route list (e.g. remotePBX_rl)
Associate the route list remotePBX_rl to the route pattern you want to send to the foreign system.
Use your locations-based CAC mechanism/test and place a call. If you set the H323 GW to BW 1kbps then what should happen is the CUCM call processing should route around the "problem" and go to the next route group in the route list (i.e. pstn_rg) and send the call out of the PSTN.
The example above is simplistic and doesn't reflect your environment. You could also use SLRG to allow remote site phones to prefer their own gateway (just like you can with AAR).
Also, the example above is focused on solving the CUCM-to-Non_CUCM call setup path. For the reverse direction (ingress call) the location setting should still initiate a call setup failure and CUCM will send the failure back to the foreign system. It is up to the foreign system to handle the error gracefully. You can look at traces to see what is sent back and then figure out if the foreign system can handle.
-Bill (http://ucguerrilla.com)
